How hard is it to remove/replace trim on door panels?
Old Aug 3, 2003 | 12:36 PM
Maximam's Avatar
Old Aug 3, 2003 | 07:14 PM
Maximam's Avatar
Anyone?
Old Aug 3, 2003 | 07:20 PM
samizer's Avatar
Do you mean the trim around the door locks and window controls or the actual door panel?
Old Aug 3, 2003 | 08:29 PM
Maximam's Avatar
The trim around the locks window switches. I want to remove the wood trim (GLE) for a dull grey trim similar to what I have in my SE.
Old Aug 3, 2003 | 09:45 PM
Papamonty's Avatar
Check out the Body and Trim file from this website:
http://members.lycos.co.uk/LucyLu112/
I removed the driver side door panel to see what was creaking in my door. When I removed the window switches, it looked as if the switches could be unscrewed then separated from the trim. Hope this helps.
Old Aug 4, 2003 | 12:24 AM
nissanman7's Avatar
Very Easy.
Old Aug 4, 2003 | 09:28 AM
samizer's Avatar
The switches can be unclipped from the door pannel and removed very easily. but I don't have woodgrain so I'm not sure if you even need to remove the switches. If the wood is like aftermarket trim you wouldn't need to, but if you need to remove the whole piece from the door pannel you will.
Old Aug 4, 2003 | 12:37 PM
Maximam's Avatar
Can I remove the OEM woodgrain trim without removing the door panel?
Old Aug 4, 2003 | 07:38 PM
Papamonty's Avatar
Yes you can. You first have to remove the pull handle screw, the pull handle, then the power window switch finisher/trim.
Old Aug 4, 2003 | 08:48 PM
Maximam's Avatar
Are you talking about the window switches or the door handle? I need to remove the window switch trim.
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
brichi
Sep 14, 2015 05:23 PM
