Custom Maxima FSTB?
Old Aug 5, 2003 | 09:03 AM
Heetenism's Avatar
Custom Maxima FSTB?
I just bought a Custom Maxima FSTB and intalled it? How much should i tighten it? Does anybody know?
Old Aug 5, 2003 | 10:36 AM
kcowden's Avatar
Did you notice how easy the bolts came off?
Old Aug 5, 2003 | 10:45 AM
Bulldawg's Avatar
if you are talking about the strut tower bolts then tighten them to 25-30ft-lbs......no more
Old Aug 5, 2003 | 10:47 AM
badabing's Avatar
You need to get a torque wrench, homey.
Old Aug 5, 2003 | 10:55 AM
spirilis's Avatar
Just don't overtighten the strut tower bolts beyond 30ft/lbs. I did that (forgot my torque wrench was set to click at 80ft/lbs) on an old Nissan Pulsar NX, snapped the strut plate stud right off. I got rid of the car shortly afterward (for other various reasons)
Old Aug 5, 2003 | 11:34 AM
MAKSYMALNY
According to the manual, you can tighten up to 45lbs.
I tightened mine to 40lbs on the 00 and 03 and they are just fine.
-R
Old Aug 5, 2003 | 12:19 PM
ToYLeT902's Avatar
JET Speed Lab
I forgot how much i tightened mine at, o well nothing broke
Old Aug 5, 2003 | 02:47 PM
Heetenism's Avatar
help!!!!
i probably sound like an idiot but are the strut tower bolts the 3 bolts on each side? so i should tighten them around 30 lbs?
Old Aug 6, 2003 | 02:50 AM
SilverChrome03's Avatar
Re: help!!!!
PUT DOWN YOUR TOOLS AND STEP SLOWLY AWAY FROM THE VEHICLE !
.......yes they are, and yes you should to 30-35 lbs !
Old Aug 6, 2003 | 02:57 AM
Zordburg's Avatar
I have seen 43-58 ft-lbs of torque also as a range for these nuts.
I've got mine torqued to 50 ft-lbs
Old Aug 6, 2003 | 06:14 AM
Todds_max's Avatar
Just installed my custom maxima fstb yesterday. My bar had no installation instructions so I used the stillen version. I also torqued the strut tower bolts to 50 ft-lbs. I think the stillen instructions I found said the bar-to-bracket bolt/nut is to be torqued to 20 ft-lbs. Because that hardware is the same size as the strut tower bolts, 20 ft-lbs seemed a little light, so I tightened them to almost 30 ft-lbs.
By the way.... that was money well spent! It won't turn you maxima into a race car, but it definitely makes a difference. The on-center feel is much improved and the steering wheel communicates what the car is doing much better than before. That vague, unconnected feel is gone. You can feel that the front end is more rigid and controlled. The car is more enjoyable to drive, even if it's actual limits haven't changed, curvy roads are now fun. It doesn't feel like it's struggling so much in the curves. I admit I was skeptical at first, but this thing does work.
Old Aug 6, 2003 | 06:29 PM
Heetenism's Avatar
Re: Re: help!!!!
hey im new at this.. but thanks for your help!!!! ill go buy a torque wrench asap!!!
and besides the 3 bolts on each side should i do anything else.. the custom max FSTB has bolts to tighten the bar to the brackets.. should these be tightened as well?
thanks for all your help
Old Aug 6, 2003 | 06:34 PM
BlkMaXinMD's Avatar
hmmm im new to this torque stuff but when i installed my springs i just used air tools and dont kno how tight i tightened it so should i buy a torque wrench/???? even tho i have an entire body shop with bunch of air tools no torque wrench
Old Aug 6, 2003 | 06:58 PM
spirilis's Avatar
A torque wrench is handy, as while air tools can be used to torque something I believe, they can be a little hard on the bolts/nuts (since an impact wrench uses a repetitious hammer action)... so having a hand wrench you can turn smoothly comes in handy whenever you're paranoid about the job.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Team STILLEN
Aug 10, 2015 04:29 PM
