Trunk Rattle, Solutions and Suggestions?
Old Aug 5, 2003 | 10:47 AM
RudeNGrimey11's Avatar
I recently put 2 15" speakers in my trunk. The system sounds pretty good but the trunk sounds like absolute shyt. I bought dynomat and dynomatted the shyt out of my trunk and it barely helped. The back deck sounds like shyt AND the rear brake light on my back deck broke because of the bass. I observed where most of the rattling was coming from and it seems like the rattle is coming from where the spare is kept. So i took out the spare and it still sounds like shyt. Anyone have any suggestions on deadening the rattle or anything that'll help? Anyone had the same problem, how'd you fix it? So far the only thing I've heard is that double-sided tape helps the license plate and holds it firm. But how can I neutralize the deck where the spare is and the other stuff. So far foam has also been suggested, however, a local audio shop said that foam builds up precipitation or some **** and causes the metal to rot in due time. I know most of you guys have your own systems, if you can't offer any suggestions, how did you deal with or fix your trunk rattle?
Old Aug 5, 2003 | 11:00 AM
brianc's Avatar
Why not buy some of that foam insulation in a can and spray the **** out of everything. It'll firm everything up as well as seal any leaks. Of course it's messy, won't do squat for resale and God forbid you ever want to take it out but it will probbably solve your problem.
Old Aug 5, 2003 | 11:07 AM
Which foam spray is this, has it worked for you, and are you sure it'll work, because if it's going to make a big mess and still not help, then that'll just suck
Old Aug 5, 2003 | 01:22 PM
Also, has anyone found dynomat successful, exactly where did u dynomat?
Old Aug 6, 2003 | 09:52 AM
Anyone try the dynashield spray, is this any good or are there much better foam in a can sprays?
Old Aug 6, 2003 | 12:17 PM
Max2000SE's Avatar
People swear by "Peel N Seal"...Cheap alternative to dynomat...Can be found in the roofing section of your local Home Depot or Lowes...
Old Aug 6, 2003 | 02:02 PM
asu174's Avatar
Clay Aiken has fancy genitals
Spray stuff sucks.
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
maxinout93
Oct 31, 2015 02:04 AM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
