FTSB question concerning alignment
They hold the strut's top plate to the chassis.
If you're worried about alignment, I'd make sure the car's sitting on a perfectly level surface with the front wheels straight before loosening them, make sure the FSTB's collar plate sits flat, and torque each nut identically (and USE a torque wrench, for that matter)... and then get the alignment checked if you're REALLY concerned.
I took my old car (a '90 Mazda 626) to a shop for alignment once, and they said the camber was off for both front tires, and they had to unbolt that strut plate, lower the strut/wheel and rotate the strut plate, tighten the nuts again, check the alignment and keep doing that procedure until they find a configuration that falls within spec. (They charged me an extra 1hr labor for it, too, heh...) So I do believe that top strut plate has influence on the alignment, particularly camber...
Any other comments?
Any other comments?
They hold the strut assembly to the strut tower which is a part of the cars frame, and installing a FTSB will have no effect on your allignment. I just put one on and like the way it helps the car handle. The car handles better but i think adding a RSB will really tighten things up. Good luck
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
