is this ECU as good as other ones?
Old Aug 7, 2003 | 11:26 AM
scopium
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426602522
Old Aug 7, 2003 | 11:28 AM
jttaylor155
sounds like cr@p to me
Old Aug 7, 2003 | 11:29 AM
skandalouz's Avatar
YES, they're just as worthless as all the others out there on ebay...
Old Aug 7, 2003 | 11:32 AM
jttaylor155
i will sell you some wires and fuses and curcuits all stuck together. you just put it in your glovebox. the ECU will "know" its there
cost is $40 but will increase HP by 50!!!
Old Aug 7, 2003 | 11:37 AM
jttaylor155
Originally posted by jttaylor155
i will sell you some wires and fuses and curcuits all stuck together. you just keep it in your house. the ECU will "know" you bought it
Old Aug 7, 2003 | 01:53 PM
scopium
so i shoud just get the original one for maximas
Old Aug 7, 2003 | 01:59 PM
soundmike's Avatar
Very sound, Mike
Is your ECU busted? If not then don't fix what's not broken. There has been no proven (customer) gains from these aftermarket ECU's that i know of.
Old Aug 7, 2003 | 02:02 PM
davidme's Avatar
what do you mean by original ?
why do you need to replace it ?
Jim Wolf, I here, is working on a replacement ecu for the 02-03 maximas
Would run ~550 dollars with coreswap but it has yet to be released
his would increase HP, TQ and MPG if what i've read is correct
Old Aug 7, 2003 | 07:49 PM
bk2kmax's Avatar
I think that ad means LYING instead of LION.
Why isn't there a clear picture of it?
Old Aug 7, 2003 | 08:44 PM
mille_3's Avatar
Which is it? 15hp or 20hp. Just reading the ad makes you not want to buy.
Old Aug 7, 2003 | 08:53 PM
davidme's Avatar
Complaint : Miss leading AD, this is only a resistor not a chip, excessive shipping charge
Complaint : This was not a chipbut a 10cent resister. Ipaid 3.95 S&H for a stamped envelo pe
Complaint : thought would be a chip but really was just a resistor i could have bought .10
Complaint : Its not what the name says it actually made my car more slugish
If you put picture into a viewer and zoom in you can see IT IS just a resistor. 10 cents at radio shack
Old Aug 7, 2003 | 10:01 PM
scopium
i have an auto and i want to change gear points..
Old Aug 7, 2003 | 11:15 PM
woosh's Avatar
There is some real hope but it's at best a $400 investment with no guarantees. There is a 16 bit rom chip, that holds the code. I'm still pondering if this is worth it. At best I see 10-15 HP for NA applications, for boosted unknown.
Better men than me have given this a shot and failed. It won't cost $31 dollars.
Not in this lifetime or the next
SHIFT_woosh
MaxLife17
Jun 27, 2019 01:37 PM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
