Throttle Body HP increase?
Old Aug 9, 2003 | 10:31 PM
thetemptingone's Avatar
Throttle Body and HP increase!
On a 2003 Maxima with CAI would it be benefitial to bore out the throttle body? Or is it possible I could actually lose out by doing so!
Old Aug 10, 2003 | 09:42 AM
studman's Avatar
There's nothing to bore... maybe 1 mm. The TB is 70 mm, and the housing is 73 mm or so. With the CAI, you don't need to modify the TB, as they are the same size.
Old Aug 10, 2003 | 01:23 PM
02MaXiMa_GLE's Avatar
If you're posting a Question, it's wise to end your Title with a Question mark "?" and not with an Exclamation point "!"
It helps readers determine whether you asking a question, or actually enthusiastic about completing the mod...
I thought that you were going to explain to us how your bored-out throttle body increased HP significantly in your Max...
G
Old Aug 10, 2003 | 08:24 PM
MAKSYMALNY
G
Quit being so nitpicky.
Old Aug 10, 2003 | 08:28 PM
davidme's Avatar
nitpicky or not
he and I though the same thing
Old Aug 10, 2003 | 10:02 PM
Greek to the Max's Avatar
You know, when you start complaining about those things, then life is treating you to good.
Old Aug 10, 2003 | 11:35 PM
Shut up Lazy Greek!
What's up with you malaka?...
I am busy as hell nowadayz! No time for MSN anymore... Email me sometime.
Later,
G
Old Aug 10, 2003 | 11:51 PM
irvine78's Avatar
with 95-01 Maximas...you can actually upgrade your throttle body with that of a Pathfinder ones...i think ours is a 60mm TB, and the Pathfinder uses 70mm(i think, don't quote me on these numbers, but i do know that they're bigger in diameter than Maximas'). but i don't know about the 02 and up....
Old Aug 11, 2003 | 08:36 AM
ela malaka, pou eisai?
Old Aug 11, 2003 | 10:29 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Is it plug-n-play?
Old Aug 11, 2003 | 12:30 PM
Y2KSESteve's Avatar
Originally posted by IceY2K1
Is it plug-n-play???
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
maxinout93
Oct 31, 2015 02:04 AM
trsandrew
Oct 25, 2015 02:47 PM
bumpypickle
Sep 20, 2015 08:22 AM
