Rear suspension?
I have a 2001 SE which (naturally) came with the sport suspension. Now I even noticed this in my 2001 GXE (which didn't have the sport suspension). I assume due to the wheel span frmo front to back, along with the tight suspension, everytime I go over a bump that is big enough and a "normal" car would bounce up and down over it, the Max takes it nice and tight (as we'd all want) but then the back THUMPS down as if the suspension doesn't want to "give" enough to let it bounce over it. I chalk that up to its tightness and I never really wanted to do mods on my car (for lack of money and know-how), but is there any suggestion on this? Does everyone's do this? Even with aftermarket springs and struts?
Please let me know.
Please let me know.
No matter what Nissan wants to call the rear suspension, it is still a live axle is limited wheel travel. The 5th generation Maxima's aren't known for great wheel travel, but thats why they handle so tight. I have a GLE;my rear suspension doesn't thump until I hit a series of ripples, then again its quiet. Sometimes to rear end feels like stepping out of line on potholes but regains its composure. There are aftermarket supplies to increase suspension travel, but the live axle will always thump over bumps.
multi link beam suspension
I think that is a characteristic of the linked beam suspension. What gives the maxima its cornering ability is also the same thing that gives it the stiff rear thump. (...i'm referring to the suspension...)
If Nissan were to use an independant rear suspension, I would think it would require additional more expensive equipment (stabilizer bar?) to have the same cornering effect that we enjoy so much now; and it would place the car in a higher price range.
The lack of independent rear suspension makes for a rough ride over surfaces that are not smooth. This is perhaps the main reason you feel that the ride is rough. The SE suspension is noticeably stiffer than the GXE or GLE, but they all feel a bit rough at times because of the rear suspension. Aftermarket springs will be even worse in terms of harshness or stiffness.
Originally posted by max2kgle526
Ive noticed that while riding in 4th gens though.
I think that may be true on smooth or track conditions, either that or the Nissan PR spin cycle on why they needed to save money. But just riding in a GS400, BMW 3 series w/ sport susp, or even an A41.8t quattro w/ sport suspension the ride quality over bumps is superior to the Maxima.
I'm not dumping on my beloved Maxima as I love the price, handling and performance. I guess it's just a tradeoff that we need to make.
Originally posted by yo_its_ok
The multlink rear beam is just as good if not better than a IRS. The camber doesn't change in hard corners, and contact patch remains flat no matter how much you push it. There is a link in the middle known as a Scott Russell Link. That link is placed in the middle and supported by Urethane with a certain stiffness that allows motion like an independant suspension. Supporting the beam are two panhard bars that have a compliance bushing allowing movement in the beam. Within the beam is also a "Stabilizer bar." ; which further stiffens the car.
The whole system weighs less than a true IRS from the 3rd Gen, handles better in General, and costs less. Since you have a new car (2001) The suspension is still fairly stiff, and will "break-in" over time, then you'll be on Eibachs, and really enjoy your ride.
I Do....
-Peace
I Do....
-Peace
A good solid axle will work better than a poor IRS, but ultimately an IRS will be better. A solid axle can work very well indeed - until there are bumps in the road. The Maxima lost it's IRS for cost reasons. Most of the time the handicap is not noticeable, but - hit a bump while the chassis is loaded in a corner and you will really feel that screwy rubber filled transverse link arrangement (A simpler watts link would have been better). Also, solid axles will not match IRS ride quality on bumpy roads - especially on single wheel bumps. The Maxima is pretty good, for a solid axle. It even has some negative camber built in. It's a compromise you can live with when you figure the cost of comparable cars with IRS. (Also one of the reasons I would have bought a Galant V6 instead - if it had a stick).
Dave
Dave
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
