Nissan Service/TCM
Old Feb 8, 2001 | 06:06 AM
Max 1109's Avatar
I finally called the dealership and set an appointment to have my transmission checked. I haven't mentioned the most recent service bulletin yet, which I have thanks to the folks here. I just told him that I have been noticing some slipping between first to second. I asked if he had ever heard of anyone having a problem like that with the 2000 max. He said "NO, never." Now I'm worried. I got a bad vibe over the phone. I'm worried that if the trans does not slip when he drives my car, that he will not offer to replace the TCM.
I need some advise.
Should I show him the service bulletin first thing, since he has already played dumb with me? What if he does not offer to replace the TCM after I show him the service bulletin? Is there a way to absolutely verify that my car has a defective part, so that there is no room for doubt even if my trans does not slip when he drives the car? Thanx.
Old Feb 8, 2001 | 06:22 AM
punkdork's Avatar
My best luck for reproducing the slip came with heavy throttle up a hill. Try to get good at reproducing it and then if he can't repro, have him go on a drive with you. If that doesn't work... you might be able to get him to check your transmission oil pan for metal shavings and you may end up with a new transmission like me.
Good luck... and if all else fails.. try another dealer.
Old Feb 8, 2001 | 06:36 AM
DMAX
TCM.......
Just had mine done. My tranny slipped in every gear, mostly 2nd to 3rd. More often when it was cold. The dealer said they had a few, but I got the impression they are completely aware of the problem. I am sure they will not give you a hard time.
Old Feb 8, 2001 | 08:57 AM
punkdork's Avatar
Remember... the TCM isn't the only answer anymore... you might have faulty solenoids. If the slippage continues take it back.
Old Feb 8, 2001 | 07:26 PM
edadams's Avatar
The solenoid replacement stopped all my slippage problems.
And the dealer turned the front rotors per the tsb concerning over tightened rotors. The dealer found no metal shaving in the trans.
Old Feb 9, 2001 | 03:37 AM
Max 1109's Avatar
Thanks for all the advice. My service appointment is Monday...I'll keep you informed if I have any problems.
Old Feb 10, 2001 | 06:10 PM
jayc5627's Avatar
TCM
I took my to a dealership already and I also showned them the paper. 2 hrs later, they called me and told me that there is nothing wrong with my transmission. It delays becasue I changed my tires to 18". Nissan sux.
J
Old Feb 10, 2001 | 06:42 PM
UMD_MaxSE's Avatar
Got Bent?
Re: TCM
J
What??? The transmission shifts funny because you have 18" tires? That is perhaps the most f'd up response I have ever heard. Take it to another dealer. Those guys obviously have no clue about anything.
Old Feb 10, 2001 | 06:53 PM
jayc5627's Avatar
TCM
I no, tell me about it.... I needed the car that day so I didn't argue with him.
Old Feb 10, 2001 | 07:37 PM
Paul6speed's Avatar
Re: Re: TCM
That is major BS. Go back with the TSB in hand.
http://www.his.com/wc/maxima/tsb039.pdf
J
Old Feb 10, 2001 | 07:41 PM
jayc5627's Avatar
TSB
I did, I showed them the freaking paper.
Old Feb 10, 2001 | 07:45 PM
Paul6speed's Avatar
Re: TSB
That's pitiful. That really sucks. Any other dealers nearby?
Old Feb 10, 2001 | 09:54 PM
punkdork's Avatar
Took me 5 times to get them to find a problem... then they ended up haveing to replace my whole tranny. Have you tried dealing with the service manager? I mean the TSB even has a list of affected VINs.
Old Feb 11, 2001 | 07:48 AM
Thump
Changing Tires And Rims
I don't know about Nissan but on GM vehicles when you change tire size, rims or gears and are not close to factory it will change the characteristics of your transmission. It thinks the car is actually going faster or slower than actual because of the change and will change the timing on the gear changes set by factoy. That is why most GM owners when changing tire or gears will buy a Hypertech tuner to adjust the change and get the transmission back in tune with the changes made. This mainly effects automatics. It's just like disconnecting the computer connection to the sensor that sends signals to the computer telling it if the car is moving and oaw fast. If disconnected on GM vehicles the transmission freaks and sometimes doesn't allow the transmission to change gears at all and stays in first gear. GM made sure that if trying to disconnect the speedometer to save on milage it doesn't let the cars run properly.
Old Feb 11, 2001 | 08:34 AM
UMD_MaxSE's Avatar
Got Bent?
Proper plus-sizing of tires should have almost no affect on gear ratios or transmission characteristics. If the overall diameter of the wheel + tire stays the same or close to stock, nothing will be off. Transmission slippage in this case is due to either faulty shift solenoids or bad programming of the transmission ECU. I never knew that about GM cars though
Old Feb 11, 2001 | 09:02 AM
Max 1109's Avatar
My service appointment is tomorrow...still hope there's no reason to be nervous.
Old Feb 12, 2001 | 06:29 AM
DMAX
TSB
Can anyone tell me I can obtain the TSB papers?
Old Feb 12, 2001 | 06:34 AM
punkdork's Avatar
Use the link in my sig.
Old Feb 12, 2001 | 08:51 AM
xtantmaxima's Avatar
Thanks to whoever posted that tsb on that website. It is so much nicer to have the entire tsb in hand instead of just the # that nhtsa gives you. My favorite part is #1 and #24, if the techs don't do this give them hell.
Old Feb 13, 2001 | 05:34 AM
Max 1109's Avatar
Dealer called me at work and said the problem could not be replicated. I reminded him that my vehicle was made during the affected period. He said he would keep the car overnight and call me today. He wanted to test drive it after it had sat overnight and was cold. Maybe I'll luck out and have a perfectly operational TCM...? Or maybe I have an intermittent problem that eventually screws up my tranny. Atleast the service department is fixing the interior cloth on the passenger's door, which appears uneven and loose.
Old Feb 14, 2001 | 01:21 PM
rino_2kmax's Avatar
tcm
hey i have a y pipe and intake
do u think that if i bring it to my nissan dealer
they will say it is cause of that
and that warrenty is canceld???
Old Feb 14, 2001 | 07:23 PM
edadams's Avatar
I would remove the intake just to be safe, the dealer will only have the car in the air if they change the soleniods, so it is not likely they will see the y-pipe. Sometimes nissan service departments can be *****Y. I had a dealer give me a rough time on my 4th gen max with intake and many other mods.
Old Feb 15, 2001 | 05:09 AM
Max 1109's Avatar
NO TCM
Dealer said that my car performs within specs and tranny didn't slip once when he drove it. No new TCM for me. Hopefully my car is one of the few built right.
Old Feb 15, 2001 | 06:37 AM
jayc5627's Avatar
My turn
It's my turn today, I am goin to take my max to a different dealer today. Hopefully I'll get it replace this time. WIsh me luck guys.
Old Feb 15, 2001 | 08:37 AM
rino_2kmax's Avatar
Re: My turn
hey jayc
ur from nj right??
let me know how everything works out
since you have a modded car and i have a modded car
if they let u fixs urs ill go to the same dealer as you
im from nj also
i dont mind driving far so i can get it fix
let me know what happens
thanks
Old Feb 15, 2001 | 05:17 PM
jayc5627's Avatar
Result
Just got my car back. Good news and bad news. THey told me the problem do apply to my car and the chip is on national back order. Another bad news is that they told me my front breaking pads r bad and possible rotors change. I was like whatttttttttttttt. I only have 12000 miles on it. And he told me that it's not covered under warranty. : (
Old Feb 15, 2001 | 07:22 PM
Paul6speed's Avatar
Re: Result
I must have a good dealer. Gaithersburg Nissan replaced my warped rotors imder warranty. I don't think pads would be covered under warranty, unless they are defective. They also took care of my TCM and solenoid.
Old Feb 15, 2001 | 08:03 PM
jetdriver1975
Actually, your rotors *are* covered up to 120000 miles...
check out your warranty booklet and show it to the dealer.
Mar 12, 2020 12:06 AM
Bernhard
Sep 14, 2015 12:49 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
coasterswim
Sep 2, 2015 07:43 AM
