custom maxima FSTB install question?!?!
Old Aug 15, 2003 | 03:47 PM
trey
OK, i know its an easy install, everything went great until i closed my hood. Now my hood doesn't lay flat like it used to because the fstb is knocking up against the hood insulation.
I even cut out some squares in the insulation where i can see that its been pushed up, and now my insulation looks like **** all chopped up and my hood still isn't laying flat
anyone have this problem?
Old Aug 15, 2003 | 05:07 PM
hct67's Avatar
You should look through all the posts on here before you ask that question, there is a post from yesterday that has many of your answers!!!
Old Aug 15, 2003 | 06:52 PM
trey
Ok, i'm not a newbie here, i have like four threads saved on my computer about installing the progressive RSTB and obviously the search option is down. I don't recall anyone having trouble with the clearance from the RSTB and the hood insulation.
Old Aug 15, 2003 | 07:05 PM
hct67's Avatar
FSTB
Wat kind of Front Strut Bar did you purchase? Was it made for the maxima?
Old Aug 15, 2003 | 07:11 PM
davidme's Avatar
well the thread title is
"custom maxima FSTB install question?!?!"
trey
Re: FSTB
It is from customaxima.com, and yes it is for a maxima, its a progresive one. I mean i can still close my hood but it
just pushes up against the hood a bit.
Old Aug 15, 2003 | 07:15 PM
badabing's Avatar
Mine looked like it was going to rub but it actually doesn't. When I installed I was careful to adjust the nuts on either side of the bar so that it was tight and even on both sides. You may want to start there and see if it helps.
Old Aug 15, 2003 | 07:20 PM
trey
cool, i'll double check that! thanks
Old Aug 15, 2003 | 07:35 PM
hct67's Avatar
I have the one from custom maxima and it doesn't even come close to touching the hood, Hmmmmmmmmmmmmmmm are you sure they sent you the right one?
Heres mine for the 2003 maxima!
http://images.cardomain.com/member_i...72_24_full.jpg
http://images.cardomain.com/member_i...72_32_full.jpg
Old Aug 15, 2003 | 07:43 PM
trey
I just double checked, it is the right one, maybe its not centered just right, i'll check it tomarrow.
thanks guys for your input
Old Aug 15, 2003 | 07:54 PM
MaxVitesse's Avatar
Hct97, give the guy some slack. it's an honest question. I've got the FSTB installed trey and no problems with rubbing. Double check your install and call custommax, they are more than willing to help.
Old Aug 15, 2003 | 08:22 PM
CCx's Avatar
CCx
installed mine a few days ago and have had no problems with it rubbing the hood or the engine...only thing i have to do was unplug the one clip jawn on the left side before installing, too much interference
Old Aug 15, 2003 | 08:40 PM
hct67's Avatar
I am trying to help thats all, it just seems weird that he has the right FSB and its hitting, wither the FSb is the wrong one or the hood is messed up. I amn sitting here trying to figure this out as much as he is. Its got me wondering thats all and I want to help him in anyway!!!!
Old Aug 15, 2003 | 10:06 PM
Heetenism's Avatar
i just installed the custom max FSTB and mine was actually too low.. and its pushing down on a part of my engine.. but it wasnt too high?
i would suggest tweeking the length of the bar on each side..
Old Aug 16, 2003 | 02:39 PM
trey
Ok, problem fixed.
1. I have the right FSTB just a bit higher then most for some reason.
2. The insulation isn't really strong enough to push the hood up but a little clip that holds the windshield washer hose was. The clip lays behind the hood insulation and lines up with the FSTB so i removed the clip and Bingo! the hood lays nice and flat again.
got to love aftermarket! its always an adventure
Old Aug 16, 2003 | 06:44 PM
Snolife's Avatar
What we have here is a failure to communicate
I have an 03 and mine does not even come close to the hood, somethings not right some where.
Old Aug 16, 2003 | 07:38 PM
MaxVitesse's Avatar
FSTB
I highly recommend you installing the rear one as well from Custom Max. It makes all the difference in the world. You're half way there!
Old Aug 16, 2003 | 08:49 PM
badabing's Avatar
Re: FSTB
Disagree....spend the money on an RSB instead.
Old Aug 16, 2003 | 09:17 PM
hct67's Avatar
Do you know of any companies that sell a good RSB at a decent price?
Old Aug 16, 2003 | 10:32 PM
asu174's Avatar
Clay Aiken has fancy genitals
CustomMaxima.
Cattman also sells the Progress RSB for a good price.
Old Aug 17, 2003 | 04:42 AM
badabing's Avatar
Originally posted by asu174
CustomMaxima.
That's what I got and it was well worth it. The CustomMaxima guys were helpful and it must have shipped out the minute after I ordered it because I got it in two days. One of my U-bolts was badly threaded and I had to go to Home Depot to get another one - but beyond that, installation was easy and it was money well-spent (~$127).
Old Aug 17, 2003 | 09:08 AM
SportyMax2002's Avatar
Does anyone have a problem or hear rubbing when reversing with their FSTB?
Old Aug 17, 2003 | 09:58 AM
badabing's Avatar
I've heard about this several times on the .org but I'm not sure what some members have done to correct it.
But it is somewhat common...
Old Aug 17, 2003 | 02:14 PM
trey
Re: FSTB
Yes i actually bought the RSB also but haven't insalled it yet. (just got to get the garage first ahha)
Old Aug 17, 2003 | 05:00 PM
badabing's Avatar
Re: Re: FSTB
You do know that there's a difference between the RSB and the RSTB, don't you?
Old Aug 17, 2003 | 07:18 PM
trey
Re: Re: Re: FSTB
difference? nooooooo waaaaaaaaay? when i ordered the RSB and the RSTB i thought that they were the same and interchangeable..
Old Aug 18, 2003 | 05:00 AM
SilverChrome03's Avatar
Some have used a washer on the strut bolts (between the FSTB and the body) to raise the bar by + or - a hair to clear the intake and others have just played with the bar orientation and centering with good results.
Bob
Old Aug 18, 2003 | 05:05 AM
badabing's Avatar
Re: Re: Re: Re: FSTB
Um....they're not....
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Team STILLEN
Aug 10, 2015 04:29 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
