UDP install Q on 01 Auto
There is an access plate to your flywheel that should be on the car's left side right next to the black center frame member that u can jack the car up on. Two bolts.... After u access the flywheel. there are nuts in there. I cant remember what size they were. I am thinking 14mm, but I got a huge 14mm wrench and just had my father hold it against the side of the opening while I achieved the right torque. It's hard as hell to get it at the right torque. Good luck.
To remove stock pulley:
1) Get 18"+ breaker bar
2) Obtain set of impact sockets
3) Secure socket and breaker bar on the bolt and rest against either the ground or the suspension control arm
4) Blip starter by attempting to start car, but do not start. A few blips should easily break the bolt free
To install the pulley, just torque down the bolt as much as you can. It should torque itself once you start the car again.
These may sound a bit risky, but they seem to work the best.
I sure dont. but maybe this will help.
ok. lay down under the car, centered, and chin should be right at the radiator, facing up of course. if you look up you will see a black squarish bar running from the front of the car down the part sof the car in the middle. when lookin up and to the left you will see a whiteish gray looking block. There is a flat plane that faces to the right and at the bottom on the flat plane is the access plate. If that doesnt help the sorry. but I didnt take a picture. That's the best I can do.
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
