advancing timing...
Old Aug 17, 2003 | 08:22 AM
PoLo's Avatar
2-Wheelin it...
advancing timing...
how is it done?
i know has to be done with the ODB-II, but just want to know how it's done.
Old Aug 17, 2003 | 10:10 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: advancing timing...
Originally posted by PoLo
how is it done?
you cant do it with any obd-II reader. it has to be done with consult 2 which nissan uses exclusively. hence the reason some have trouble having it performed. it is changed simply through changing the setting in the ecu from the consult.
Old Aug 17, 2003 | 10:12 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
Is advanced timing dangerous for the engine?
Old Aug 17, 2003 | 10:38 AM
studman's Avatar
If you only advance it to +17° BTDC, then no. But if you advance it more than that, it can be. Also, if you are SC/Turbo/FI, then you want your timing at normal, if not actually retarded (which the FMU/ECU would do).
Old Aug 17, 2003 | 10:39 AM
spirilis's Avatar
It can promote pinging/detonation, moreso than normal, but if you don't advance it much, and use premium gas ALL the time, it may yield better performance. However, if it pings a lot (or worse, detonates) your performance will suffer as the Knock Sensor will cause the ECU to retard the timing somewhat unpredictably, and if it continues on a lot you can damage the engine.
Old Aug 17, 2003 | 12:08 PM
00MaxSE's Avatar
Pointy Elbows
Exactly how much performance gain is there from advancing your timing? Is it noticable? Is this the type of thing to do only to boosted cars or N/A?
J.
Old Aug 17, 2003 | 01:40 PM
sloppymax's Avatar
J.
you should notice a difference even stock NA. i had a few mods when i had mine advanced and i could definately feel a bump in power in lower rpms. it also promotes efficiency of the motor and a slight bump in mpg was noticed by myself and a few other members. the best way to describe is that it takes less effort to come up to speed from a stop or low roll.
Old Aug 17, 2003 | 07:11 PM
00MaxSE's Avatar
Pointy Elbows
Sloppy, do I just ask my dealer to have this done? How much does it cost?
Also, I did that mod you told me about with the tube leading air from the scoop to the intake. Did you use dryer vent tubing for yours? That's what I did.
Old Aug 17, 2003 | 07:26 PM
foodmanry's Avatar
Da Roller Coaster!
It's cost is $40 to $5 at the dealer. Some dealers may turn you down for it because they say it's out of specification, but it actually is within specification for the engine. I got rejected at the first dealer I went to, but the second one had no problem with it.
Old Aug 17, 2003 | 07:33 PM
sloppymax's Avatar
i had mine done at a local shop that specializes in nissan and infiniti. i found out they purchased the consult 2 from nissan so blubyu2k2 and i bugged them for a while and they allowed us to use the consult and we actually did it ourselves. it was real straight forward and took no time at all. blu had his done for free since he was having some other work done and i think i paid like 20 since that was all i was there for. i couldnt tell you the name of the stuff i used on my intake, it was some kind of hest resistant large tubing used on carbureted cars. i went with it cause it dark to blend in the bay but it probably ends up holding more heat because of the color than the reflective color of dryer vent.
Old Aug 18, 2003 | 06:49 AM
BiggD23
I remember reading that the ECU won't let you go more than 2 degrees up or down from the factory setting, which is 15° BTDC. So anything under 13° or above 17° would be rejected.
Old Aug 18, 2003 | 06:53 AM
190hpKiLLA's Avatar
Granny Driven
OK, Where can I get my timing advanced besides the nissan dealer in NY ASAP. I have to be ready by wed.
Old Aug 18, 2003 | 07:12 AM
MAKSYMALNY
Not true
I had mine advanced 3 degrees... and the tech who did it for me has a 2003 Max that he also advanced 3 degrees.
=R
Old Aug 18, 2003 | 08:00 AM
BiggD23
Originally posted by MAKSYMALNY
Not true
=R
Right, but was your stock setting at 14° or 15° before he did it? Some Maximas come set at 14° from the factory, meaning you could increase it 3° to get to 17° BTDC. I think the ECU assumes 15° is the factory setting and allows +/- 2° from there. This could be wrong, it's just what I've read on the org.
Old Aug 18, 2003 | 10:03 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Ok...I wish the search feature worked, so I don't have to repeat this but anywho.
First, the stock timing for a 2K1 is 15-degrees +/-5, so 20-degrees is within spec.. However, I've seen a 2K FSM say +/-2 for the same car. I'm not sure what the FSM recommends for the 2K2, but I'm sure 5-degrees is perfectly fine.
Second, the reason you can't bump the timing more then 2-3degrees before the ECU stops you is because you need to perform an IDLE AIR VOLUME LEARNING procedure after 2-3degrees, then try advancing it further. My THEORY on why this occurs is because as you advance the timing, you're also increasing the base idle, which the ECU controls by adjusting the timing so it stays in spec.. Once you modify any parameter the ECU relies on for base values such as base timing, base idle, TPS value, or MAF value far enough, you must perform an IAVL procedure, so I'm expecting that is the reason why you can't go past 2-3degrees.
Third, this ECU advance is ONLY base ignition timing, which will be overcome/outweighed by the normal advance that is added throughout the RPM band. So, you may eek out a little more power from say idle to 2000rpm, but after that the ECU has added far more advance and accounted for the base-timing change.
Fourth, I doubt this mod is very beneficial to MANUAL transmission cars, because of how we normally throttle up the RPM(also adds advance) before we engage the clutch and shift above 2000rpm. However, cruising in a higher gear with the RPM below 2000rpm could be more responsive. I think the biggest gainers from this mod are for automatic trans. cars, where you just punch it off the line.
Old Aug 18, 2003 | 10:06 AM
PoLo's Avatar
2-Wheelin it...
thanx man..i was weary in reposting this, since it has been mentioned many a times, but as we know, that search isnt'w orking well, and i tried every combination i could think of, with no avail. thanx though. we'll see what i do. i'm running this wed. i wanna finish up last minute tweeks before i hit the track.
Old Aug 18, 2003 | 10:15 AM
MAKSYMALNY
Ice... thanks for the explanation! I think you spelled it out very well
Old Aug 18, 2003 | 10:45 AM
foodmanry's Avatar
Da Roller Coaster!
Oh sweet....good explanation Ice.
Old Aug 18, 2003 | 01:31 PM
y2kse's Avatar
FWIW, I have a manual tranny in my 2K SE and I definitely feel an improvement in low-end torque with my timing advance increased to 17 degrees BTDC. It's not a night and day difference, of course. But any mod that doesn't cost too much and improves low end performance on the 3.0L engine is worth it AFAIC.
Old Aug 18, 2003 | 02:25 PM
raynist's Avatar
Are we talking about advancing the base timing +2 degrees? From what I know about other cars I have worked on, advancing the base timing advances the timing that amount through the whole rev range barring any timing retard by an aftermarket ignition, or a knock sensor.
If you advance your base timing from 10 BTDC to 13 BTDC, you just moved the whole timing curve up my 3 degrees from idle to redline. Maybe things are different with the Maxima, I am not sure.
--Ray
Old Aug 18, 2003 | 02:38 PM
IceY2K1's Avatar
--Ray
That's only for mechanical advance systems.
Definitely NOT for distributorLESS ignition systems.
Old Aug 18, 2003 | 02:41 PM
IceY2K1's Avatar
Got dyno?
Butt dynos don't hold water on these small differences IMO.
I'm not saying don't do it just for the heck of it though.
Old Aug 18, 2003 | 02:43 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Actually, that's not correct. The service manual specificlly states 15 degrees plus or minus 5 degrees, so a total of 20 degrees timing before top dead center is still within Nissan specs.
EDIT- Doh! I should have read the entire thread. Sorry to double post Icy!
h2kFrosty's Avatar
FWIW and AFAIC??? You abbreviate whole sentences. :P
Bryan
raynist's Avatar
That's only for mechanical vacuum advance systems.
Ok, the cars I worked on did have distributors, but not vacuum advanced.
--Ray
Old Aug 18, 2003 | 02:50 PM
IceY2K1's Avatar
--Ray
Edited..
I've only worked on vacuum advanced mechanical distributors.
Old Aug 18, 2003 | 08:53 PM
y2kse's Avatar
Re: Got dyno?
I understand your point, Ice. But most who have had their timing advanced say that they can feel a difference, and I'm one of them. Inaccuracies of butt dynos notwithstanding, I agree that those who are interested should do it for the heck of it. Chances are, they'll like it too even if the performance increase doesn't really count.
Old Aug 18, 2003 | 09:02 PM
y2kse's Avatar
Bryan
If you think that's something, Bryan, you ought to see what I can do with smilies!
Old Aug 18, 2003 | 09:07 PM
IceY2K1's Avatar
Re: Re: Got dyno?
Agreed...too many people claim it makes a difference for me to easily discount it as the placebo effect. It can't hurt UNLESS you get detonation, which is unlikely so why not if it's not to much $$$$.
Old Aug 19, 2003 | 05:58 AM
raynist's Avatar
Edited..
I didn't think my 89 Mustang GT or 95 Ford f-150 had vacuum advance. There is no vacuum line connected, I certainly could be wrong though.
Old Aug 19, 2003 | 07:03 PM
y2kse's Avatar
Re: Re: Re: Got dyno?
Unlikely, but not impossible. I do, in fact, experience a little low rpm detonation in hot weather or when I heat soak my engine. I won't take the time to discuss why that may be happening, although I have my hunches. But the way I get around it is by adding 1 gallon of 100 octane gasoline to every 8 gallons of 91 octane I pour in the tank. (I'm in California, and all we can get here is crap 91 octane gas.) Doing that increases my overall octane rating to 92 and puts an end to the detonation no matter how high the temperature rises.
Old Aug 19, 2003 | 08:26 PM
OT n00bs FTMFCSL
Gotta love Georgia gas!!! Our worst premium is 93 octane. I haven't had any audible pinging at all...
Old Aug 19, 2003 | 09:26 PM
IceY2K1's Avatar
Re: Re: Re: Re: Got dyno?
Do you have an OBD scanner?
It would be interesting to see if the ECU is retarding your timing to counter the detonation. However, if that's only when it occurs, I wouldn't worry. The ECU won't allow enough to be damaging.
The extra octane helps keep some of the power you normally have when it's not so hot out.
Old Aug 19, 2003 | 10:15 PM
Tony Fernandes's Avatar
First of all...this thread is AWESOME. Most informative one I've read in a while.
Pardon my ignorance, but what is pre-detonation? In other words, if I had the timing advanced too high, this is something I would immediately notice and ask to have it re-adjusted? Is it just the opposite of knocking? I'm mostly interested that if I had the timing advanced and didn't like it for some reason, that I could be reasonable assured that a dealership could reverse it back to normal without having to take the car back a bazillion times and so on and so forth.
Tony
Old Aug 19, 2003 | 10:24 PM
IceY2K1's Avatar
Tony
There is no such thing as "pre-detonation". It's either detonation or pre-ignition. Detonation is analogous(sp?) to pinging or knocking and depending on engine design, can occur for long periods of time without serious damage.
Pre-ignition will destroy the motor in seconds.
Old Aug 19, 2003 | 10:51 PM
Sorry...pre-ignition is when the gas mixture in the cylinder is ignited before the cylinder reaches the top of its stroke? I assume this would be an extremely RARE occurrence if a certified dealership was the one performing the advancement?
Tony
Old Aug 19, 2003 | 10:53 PM
IceY2K1's Avatar
Tony
Tony
I STRONGLY suggest you read this to understand more then you ever cared to know about this subject.
Engine Basics: Detonation and Pre-Ignition
Old Aug 19, 2003 | 11:15 PM
BJS 3.5SE's Avatar
thats a crazy article.........
Heres my 2cents.
i had my timing advanced by Nissan 2 degrees, using their Consult scan tool, so far they r the only scan tool with reflashing programs for our cars. i also made 2 trips to the dragstrip since, and have seen my MPH go up just a bit....
The theory is that the more timing advance u can get, without detonation, the more power u will produce, but the problem ur vq's have, is that we have some overactive knock senosrs (A good safety measure), so unless ur runnin in Ideal conditions with high octane gas, u won't see that few extra hp u CAN gain....
U guys may know this, but the most they can reset the timing with the scan tool is 3 Degrees off of factory base timing, in my case 15 degrees btdc...........
I'll shut up now
Old Aug 19, 2003 | 11:45 PM
IceY2K1's Avatar
You missed page one?
Old Aug 20, 2003 | 08:02 AM
BJS 3.5SE's Avatar
yea, i saw page one, maybe i didn't read it too well, but nobody mentioned what the limits of the scan tool...since the factory only lets u modify timing plus or minus 3 degress.......
Yea....i thought the advance slighty helped, but then again...... along with my buddy, were tryin to setup a driver system for my Variable intake cams,, maybe that will help me more.......
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
Luev
Sep 30, 2015 11:50 PM
sliptap
Sep 30, 2015 05:57 AM
