Spark Plug Gap??
Old Aug 17, 2003 | 11:23 AM
maxcosity's Avatar
Spark Plug Gap??
What should the gap be on some new NGKs?
Thanks,
Kevin
Old Aug 17, 2003 | 11:46 AM
spirilis's Avatar
.044" I believe. If you're gapping Platinum plugs, be careful as you can scratch the platinum surface off easily, so I've heard...
Old Aug 17, 2003 | 12:56 PM
Y2KSESteve's Avatar
If you're NA, I'd just leave the gap where it is...
Old Aug 17, 2003 | 01:07 PM
maxcosity's Avatar
These aren't specific to Nissan Maxima, so the gap is probably wrong..
Old Aug 17, 2003 | 01:23 PM
spirilis's Avatar
I'm not positive, but all the cars I've ever worked on (Ford Tempo, Mazda 626) all used .044" plug gaps. I guess that's a pretty standard gap for cars?
Old Aug 17, 2003 | 05:52 PM
maxcosity's Avatar
Are you guys sure? You don't need to adjust them at all??
Old Aug 17, 2003 | 06:51 PM
UMD_MaxSE's Avatar
Got Bent?
always check the gap before installing. Even if you get pregapped plugs, which you most likely will, still check the gap to make sure.
Old Aug 17, 2003 | 06:59 PM
maxcosity's Avatar
I know that, but I need to know what the CORRECT GAP should be. ANYONE???
Old Aug 17, 2003 | 07:06 PM
spirilis's Avatar
maxcosity: .044" is the correct gap!!!
Old Aug 17, 2003 | 07:10 PM
UMD_MaxSE's Avatar
Got Bent?
the part # of a pregapped plug usually has the gap in it.... i.e., BKR5E-11: the -11 means pregapped to 1.1 mm = .044"
Old Aug 17, 2003 | 07:22 PM
maxcosity's Avatar
ok, 0.44 it is. Thanks!
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
