Bypass valve for InjeN....!!!!!
Old Aug 19, 2003 | 01:57 PM
MaXiMized MAX02's Avatar
hi guys....does anyone know where to get a bypass valve for the Injen CAI....? thx alot...
Old Aug 19, 2003 | 05:04 PM
gtbigup's Avatar
Check to see if the AEM valve can fit the you can buy from their site www.aempower.com. I had one on my PR CAI.then i took it off.Dont need that unless ur filter is going to submerged in water plus you'll notice the power loss after installation.
Old Aug 19, 2003 | 05:12 PM
KLOOGY's Avatar
L33t BMW Drivah
http://forums.maxima.org/showthread....hreadid=235625
There is one for sale on the FS forum.
Old Aug 20, 2003 | 01:08 PM
thx alot guys for the reply....still deciding....thx for the info
Old Aug 20, 2003 | 01:31 PM
MAKSYMALNY
You don't need a bypass valve unless you are turbo/supercharged.
The Injen is only an intake and doesn't have the pressure of a turbo/supercharger... hence, no need for a bypass valve.
-R
Old Aug 20, 2003 | 02:18 PM
Y2KSESteve's Avatar
-R
The engine in your car is always sucking air and if water is where the filter is, it will suck water up into your engine. The bypass valve gives the water somewhere to go in case you do happen to get water near the filter or drive through a big puddle. Boosted people as well as NA people could have a use for it.
Old Aug 20, 2003 | 07:58 PM
irvine78's Avatar
-R
no, that's not true. just because you're N/A, doesn't mean that you won't suck up water when the filter is completely submerged in water.
Old Aug 20, 2003 | 08:41 PM
SeaFoam2DMax's Avatar
Oh hi....
I got an AEM on mine, there was a power loss but as much as it rains in central Fl during the summer, there are some serious deep gatherings of water that sneek up on you. curse the thunderstorm
Old Aug 20, 2003 | 08:49 PM
Lumbee1's Avatar
Are you really driving through water that is a foot deep?
Old Aug 20, 2003 | 08:57 PM
Oh hi....
not if i can help it. let's see, raining heavily(visibility reduced), plugged drain due to the great public works of florida, and the 2in an hour rainfall that is common in summer. hmm, puddles can have a habit of appearing. before i had the intake i hit some serious puddles. when the rainy season is ended it shall be removed, or at least till i figure out where all the low points are. The last thing i want is to ingest water.
Old Aug 20, 2003 | 10:15 PM
E55AMG2's Avatar
Wat
There isnt a way to use the bypass valve with the injen stock. You would have to mod it for it to be possible.
Old Aug 20, 2003 | 10:40 PM
Y2KSESteve's Avatar
Yep, part of the Injen would need to be cut to make room for the bypass valve. About 2" of pipe would need to be cut off to make room.
TKHanson
Nov 24, 2018 01:39 AM
05' MaximaMan
Oct 8, 2017 06:36 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
