Removing engine cover helps engine...
Old Aug 26, 2003 | 03:25 PM
  #41
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally posted by DonGfun
Will this help on the 3.0 and does it come off the same way??
i doubt it will help any on the 3.0 because the anniversary cover only covers the 3 front coils and not a considerable portion of the motor like the 3.5 does. it wont come off the same way either. its either 10 or 12mm bolts, 4 of them i believe instead of allen wrench.
Old Aug 26, 2003 | 03:36 PM
  #42
Quicksilver's Avatar
OT n00bs FTMFCSL
Originally posted by jeepik
no but its really easy to notice when you have it taken in to get warranty work done
Well duhhh! Put it back in man! It only takes 30 seconds...
Old Aug 26, 2003 | 03:46 PM
  #43
DonGfun's Avatar
VW = 30 MPG
I don't remember having an anniversary cover but i did see 4 allen or torx bolts I ll take a look tonight Thanks
Old Aug 26, 2003 | 04:45 PM
  #44
asu174's Avatar
Clay Aiken has fancy genitals
No, you do not have a cover on your engine.
Old Aug 26, 2003 | 04:54 PM
  #45
MaximaMan77's Avatar
I'm having a hard time following your logic. You probably spend more time cleaning under your hood once a week than it would take to put your cover back on. In the time it takes you to do your cleaning I'll have put my cover on, pulled my intake, put the stock airbox back in and if I'm not already at the dealer when your done I will at least be on my way.
And are you going to buy another one for $150 or more so you can look stock after you take the one that has 2 4x4" holes cut in it back off.
Old Aug 26, 2003 | 05:04 PM
  #46
asu174's Avatar
1. You want to cut holes in your engine cover, yet you want the car to look stock for warranty work?
2. You don't think cutting holes it would look more ghetto than if you were to just remove it?
It seriously takes 3 minutes to take the cover off.
Old Aug 26, 2003 | 05:44 PM
  #47
DonGfun's Avatar
VW = 30 MPG
I did it 4mm allen key for 2000 SE
Old Aug 26, 2003 | 06:40 PM
  #48
jeepik's Avatar
i have a sapre cover i bought at a junk yard for 15 dollars, it was basically brand new...thats why i started thinking of it this way
its not like its gonna cost me a lot of money to cut the spare one up..plus i can make the grill mold into the cover for a clean look
Old Aug 26, 2003 | 06:57 PM
  #49
sloppymax's Avatar
you are thinking about the valve cover. 2k didnt come with engine covers. some people put an anniversary cover on their 2k and non ae 2k1.
Old Aug 26, 2003 | 07:35 PM
  #50
Glude's Avatar
So this really helps keep the engine cooler? I havent ever looked at the temp gauge really to see what it stays at. Does this really gain a lil power?
Old Aug 27, 2003 | 05:20 AM
  #51
E55AMG2's Avatar
Wat
yes
Old Aug 27, 2003 | 05:58 AM
  #52
Lumbee1's Avatar
Originally posted by E55AMG2
yes
got dyno?
Old Aug 27, 2003 | 06:04 AM
  #53
VQ35DE's Avatar
Originally posted by Lumbee1
got dyno?
Less heat = More power, don't need dyno for that !
Old Aug 27, 2003 | 07:32 AM
  #54
DonGfun's Avatar
VW = 30 MPG
so what did is take off my valve cover will that help
it was easy
Old Aug 27, 2003 | 08:21 AM
  #55
sloppymax's Avatar
it was easy
i doubt that will help anything. only thing that will do is make it easier for dirt and other crap to get near the coils.
Old Sep 10, 2003 | 09:44 AM
  #56
CVicVogel's Avatar
Originally Posted by maximaman777
That's my plan.
firebirdss, not only has this thought never crossed my mind, mine has been off long enough that if it were going to have done anything it would have by now.
jeepik, as much as I'd like to I won't throw a rofl up here on ya. Yes it would help some but it will still reflect heat back into the motor. How often do you have your hood up?
Has anyone thought about drilling some cooling holes in the cover and installing round louvers like those used on house attics. Say, about 2" diameter?
Old Sep 10, 2003 | 01:32 PM
  #57
VQ35DE's Avatar
Just take it off.
Old Sep 10, 2003 | 01:41 PM
  #58
Maximus03SE's Avatar
Any of you guys who took your 3.5L engine cover off want to sell it? Mine got pitted with acid from bad battery
Old Sep 10, 2003 | 01:55 PM
  #59
VQ35DE's Avatar
I'll take $100 plus shipping.
Old Sep 10, 2003 | 02:16 PM
  #60
Thanks for the reply and offer, but I guess I should have mentioned that Turbo95Max (Matthel) can get these brand new for $98 + shipping. I was hoping to pay less than that for a used one
I'll pay $75 + shipping for a used one if it doesnt have any blemishes on the surface
Old Sep 10, 2003 | 03:50 PM
  #61
MannyNJ2k2max's Avatar
mmm, gonna try that next time i go to the track-
Old Sep 10, 2003 | 04:51 PM
  #62
WILLSE's Avatar
has anyone else notcied that the fake chrome paint around the hamburger nissan bubbling up on the cover?
will
Old Sep 10, 2003 | 07:35 PM
  #63
VMaximus02's Avatar
Would the heat that was trapped by the engine, now being released effect those that have HAI? Unless the temperature is extremely hot, most engine w/the water cool system, should be able to dissipate the internal engine heat without effecting performance as long as the temperature gauge is registered within the "normal" range.
The plus of having the engine cover on MAY help the paint of the hood. You all know how crappy our car's paint is!
Old Sep 10, 2003 | 07:46 PM
  #64
OT n00bs FTMFCSL
maximaman777 has had his off for over a year IIRC with zero problems in regards to the paint issue. And for the record, it does keep the engine temperature down by one full needle mark as compared to stock. I am impressed, to say the least...
Old Sep 11, 2003 | 04:34 AM
  #65
FanaticMadMax's Avatar
You guys are so lucky to have a 3.5 since mine doesn't have a cover. I have wondered if the cover is made of plastic, because it would be surprising if it did reflect a lot of heat, in fact, the cover would have melted. Right guys?
Old Sep 11, 2003 | 06:28 AM
  #66
Not a full year but the last 6mos at least, the hottest part of the year anyway.
Yes it is made of plastic. You would be surprised how far technology has come with plastics. There has even been an internal combustion engine made of hybrid plastic.
The car already has valve covers; this cover is purely for esthetic purposes. The reason it holds so much heat in is not only because it traps air under it, and this would be a very small part of it. It has to do with it reflecting radiant heat back to the engine. Any one who has sat in front of a fireplace knows that your skin gets warm in a very short time but if someone or something blocks the fire, even a simple sheet of paper, you can instantly feel the difference. It's the same thing here. As far as it melting just remember that same piece of paper can reflect quite a bit of heat away from you without bursting into flames.
Cutting holes in it or anything else people have said will do nothing but ruin the cover.
Old Sep 11, 2003 | 06:32 AM
  #67
will
Yes, there was another guy talking about this recently. He described it exactly like that too. I believe he spilled oil or something on it. I don't think there is a simple fix for this.
Old Sep 11, 2003 | 06:59 AM
  #68
kcowden's Avatar
I took off my cover also and went as far as to take off the rubber gasket on the back of the engine where the hood and frame meet, it came off easily. The way I look at it is the air coming over the hood and over the windshield should create a vacume to pull the hot air from under the hood. I don't notice too much difference in the temp guage so I might be delusional but I'm happy anyway. Any thoughts????
Old Sep 11, 2003 | 07:04 AM
  #69
ahaling's Avatar
I have also removed the cover as well as the rubber seal at the back of the hood. I do not get any hood shake and it really moves the air.
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stelianos
Aug 19, 2015 02:07 PM
kirkhilles
Aug 8, 2015 10:53 AM
