Need help removing radio..Qucik!!!
Old Aug 23, 2003 | 01:25 PM
Prodigy's Avatar
I'm trying to get the radio out but I cant find what's holding it on. I have 2 screws at the bottom removed but I cant find a way to get the top undone (under the center vents). Do they need to be removed or what?. If you know please help, my interior is in pieces and I still cant get this undone!!! Thanks in advance
Old Aug 23, 2003 | 01:28 PM
asu174's Avatar
Clay Aiken has fancy genitals
Pull out the center vents. I generally prey from the sides, but be VERY careful not to screw up your dash.
Old Aug 23, 2003 | 01:31 PM
Prodigy's Avatar
So they are just clipped in?
Old Aug 23, 2003 | 01:48 PM
Max2000SE's Avatar
Yes the vents are just clipped in...They way I did it was try to pry it in an upward motion...Dont pull it directly out, it wont budge...Just be careful and pull the vent upwards and you should be safe..Then under there you will see the remaining 2 screws you need to remove to get your unit out....Good luck
Old Aug 23, 2003 | 04:55 PM
KCMichaelM's Avatar
Exactly right, and it's much more difficult than you think
Old Aug 24, 2003 | 12:10 PM
jonbth's Avatar
I used a pick tool and inserted it thru the vent and gently pryed the clip inward. I needed a pen-light to see where to pry. It's very hard the first time but easy after that.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
