difference between 2k2 auto vs 6spd
Old Aug 26, 2003 | 03:42 PM
mistermax's Avatar
how much of a difference is there between a 2k2-2k3 auto vs. a 6spd one. wat are the average 1/4 mile times for each? does the 6spd really make that much of a difference?
Old Aug 26, 2003 | 03:48 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
It can make a huge difference "IF" you know how to drive one. With full interior and full tank of gas I can run 14.8's in my auto all day long at the track. Launching my auto perfectly and stripping weight gets me in the low 14.6's (and it's traction hampered at this point on stock tires/wheels)...
The story is that if driven properly, the 6 speed is faster in all conditions. The flip side of that is that the auto is far more easily modulated (DUH!) and is vastly more consistent (except for the few pros that run on this board). It's a bracket racing machine (I waxed a total of 27 Mustangs on seperate runs this year alone in bracket racing...all of them were 5 speeds). But I'll tell you true, I like the 6 speeds better
Old Aug 26, 2003 | 05:11 PM
mistermax's Avatar
as far as modifying them, is there any major gain advantage of the 6spd over the autos in terms of hp?
Old Aug 26, 2003 | 06:19 PM
mattattax's Avatar
yes, a manual tranny will get a larger percent of the power to the wheels, but not much at all--IMHO this only really matters when have a lot of mods
my auto ran 14.6 with just the vb mod and heavier 18" wheels--it all depends on what YOU wanna drive
Old Aug 26, 2003 | 06:34 PM
mistermax's Avatar
what is a vb mod?
Old Aug 26, 2003 | 07:36 PM
chigga's Avatar
valve body my dear boy. it makes us autos shift a lot faster and it lengthens the tranny life too. how is your vb mod treatin u anyway matt?
Old Aug 26, 2003 | 07:46 PM
97GSTAT's Avatar
Who sells the parts/shift kit for the vb? I've been looking for awhile now and have yet found one.
Old Aug 26, 2003 | 07:47 PM
chigga's Avatar
its all one piece as far as i know. check maximum tuning. i know they have them
Old Aug 26, 2003 | 09:11 PM
raymond3414's Avatar
So whats the deal with this VB mod???? Where and how do you get it? How much is it? Will it void our current warantty? Pretty much any info. on this mod. will be apreciated. Thanks
Old Aug 26, 2003 | 09:21 PM
chigga's Avatar
it shifts our car a lot faster than stock valve body. it strengthens the valve body too. the biggest problem is if you dont live close to a shop that does it, u have to send in your original valve body to get the mod done. i think its like 3 or 500 dollars, somewhere in between there. its a good mod that just basically shifts the auto more sport than luxury. im not sure bout the warranty, though ask someone that has it, i've just picked all this up from searching but its down so i understand..
Old Aug 26, 2003 | 09:43 PM
looslip's Avatar
Horra!!
See... I would be so on top of this mod if I lived in the east coast. Anybody know a place that does VB mod in Cali?
Old Aug 26, 2003 | 09:55 PM
mistermax's Avatar
so does this vb mod shift faster than any maxima can manually?
Old Aug 26, 2003 | 10:23 PM
looslip's Avatar
Horra!!
With a manual its not so much a matter of shifting faster but a manual has better gear ratio, being that it has 2 more gears to work with...
Old Aug 26, 2003 | 11:31 PM
96_vqmax's Avatar
I think he is talking about manually shifting the auto tranny ???
Old Aug 26, 2003 | 11:49 PM
looslip's Avatar
Horra!!
Old Aug 26, 2003 | 11:54 PM
HitManSE's Avatar
Either way the answer is yes. If you run slicks on the auto, you can definetly hit 13's...
Old Aug 27, 2003 | 04:39 AM
mistermax's Avatar
no i am talking about shifting a 6spd.
Old Aug 27, 2003 | 04:57 AM
Blu's Avatar
Blu
the tits
well I have trapped 99 on smaller diameter tires 22". A 6 spd is more fun too drive everyday but at the track I prefer Auto on slicks
Old Aug 27, 2003 | 05:01 AM
WisMaxima's Avatar
I have always owned and will continue to own manuals for a number of reasons. Off the lot, they are inherently less expensive to buy. Manuals return better fuel mileage. They are marginally lighter than automatics and there are less parts to have problems with. And finally, if you do know how to drive it, the manual is quicker. Just my two cents. I've got a neon (which is a notoriously crappy car) that I commute with. It is coming up on 165,000 miles and I have had no transmission problems whatsoever. Haven't even had to tighten the clutch cable.
Old Aug 27, 2003 | 09:46 AM
Wisky97SE's Avatar
Go for the 6 speed . . . assuming you could drive well, you can pull a 14.3 ish 1/4 time, with the auto you're gonna do low 15's, high 14's at best.
-Wisky
Old Aug 27, 2003 | 09:52 AM
mattattax's Avatar
-Wisky
I'd say mid 14s at best
I like my vb mod a lot. Mine was made by Don but I don't think he's involved with the maxima community anymore.
Old Aug 27, 2003 | 10:01 AM
Blu's Avatar
Blu
the tits
-Wisky
really
Old Aug 27, 2003 | 10:27 AM
chigga's Avatar
Originally posted by blubyu2k2
really
last i heard stock autos was running mid to high 14's. 15's would be in bad conditions
Old Aug 27, 2003 | 10:32 AM
MaximaMan77's Avatar
5spd Maxs' have a better gear ratio in 1st-3rd for the 1/4 mile. With the 6spds you have an extra shift from 3rd to 4th, that kind of negates some of the power to the ground advantage it has over an auto. So for 2k2 & 2k3's auto's & manual's are closer to even.
Now if we could just change out a few gears in the 6spd...
Old Aug 27, 2003 | 10:40 AM
Blu's Avatar
Blu
the tits
In perfect conditions the 6spd should run at best a 14.2 @ 98. An Auto in the same exact conditions should run 14.4 @ 95. My best of a 14.6 @ 93 was in warmer weather around 80 degrees.
Old Aug 27, 2003 | 10:49 AM
Sam03's Avatar
Re: difference between 2k2 auto vs 6spd
Yes.
Old Aug 27, 2003 | 10:50 AM
kcowden's Avatar
Go to www.mobiletek.net for your info. They are having a special right now.
Old Aug 27, 2003 | 10:52 AM
Blu's Avatar
Blu
the tits
whats there special ripping people off ?
Old Aug 27, 2003 | 11:09 AM
HitManSE's Avatar
kcowden: You havnt been here long enough ro comment about mobiltek. 2-3 yrs ago they were alright, now...
Old Aug 27, 2003 | 12:14 PM
chigga's Avatar
Old Aug 27, 2003 | 01:11 PM
ga2000's Avatar
ok so what u guys are saying an 02 and 03 auto will avg low 15s stock.. and the 6spd will do mid to high 14s stock??
Old Aug 27, 2003 | 01:26 PM
Blu's Avatar
Blu
the tits
ummm no...
6spd mid 14's
Auto high 14's
thats with crappy drivers
Old Aug 27, 2003 | 01:36 PM
Maximax2's Avatar
ummm no...
6spd mid 14's
Auto high 14's
With crappy drivers? You ran a 14.6 - there's more than two tenths of a second between that and a crappy driver (unless you suck )
I think you'd have to put those time into the "good" driver category.
Old Aug 27, 2003 | 01:41 PM
Blu's Avatar
Blu
the tits
true but I consider mid 14's 14.4-14.7 and high 14's 14.8-14.99 but thats just my logic.
No biggie I want mid 13's this winter
Old Aug 27, 2003 | 02:41 PM
OT n00bs FTMFCSL
And you'll get it with ease, I'm sure blu...
We autos can definitely hold out own. I need to get smaller wheels/tires to get deeper into the 14's...then I'll start the engine/tranny mods
Old Aug 27, 2003 | 03:16 PM
ga2000's Avatar
x
i know with no mods your good for a 14.8 to a 14.9 stock with the 04, evan a 14.7
Old Aug 27, 2003 | 05:08 PM
FlexMAX's Avatar
Yes it is a big difference(If driven my Brother-in-laws 2k2 six speed several times). I own a 2K3 auto and their isn't a day that goes by where I wish that I would have bought a 6-spd. I used to always contemplate on trading my auto for a 6-spd, but I knew that I would have been raped by the dealer if I traded in my Max.
Old Aug 27, 2003 | 05:24 PM
MONTE 01&97 SE's Avatar
Low 14's = 14,14.1,14.2,14.3
Mid 14's = 14.4,14.5,14.6
High 14's = 14.7,14.8,14.9's
whatwe are saying ga2000 is that 02/03 auto should be a mid-high 14 car stock, manuals should be low 14's stock. Its been proven and beaten to death in tons of threads as this is asked at least twice a week.
Old Aug 27, 2003 | 05:39 PM
HitManSE's Avatar
...every week for the past yr if not longer...
Old Aug 27, 2003 | 06:09 PM
JAKE02's Avatar
Re: x
Maybe.....but have not seen but a few time slips for an 04, and those were in the 15's.
