anyone wired the bumper corner lights
to the turn signal lights? I think It would look awesome if the both blink at the same time. If you have, please give me directions.
All my lights up front (turn signal, corners, fogs)all clear, except for my headlights which are blue. Should I switch to the clear headlights? Or should I keep them this way?
Originally posted by mingo
i heard mingo's instructions are real confusing..
LMAO! I think I'm just gonna get under my hood tomorrow and try some wiring technics. I'm gonna see which is the signal wire, cut it and attach another wire and lead it to the corner lamps and cut the wires and attach them. If that doesn't work, well...there goes my warrenty
bassically this..
tap into the green wire on the turn signals..
chop the black wire on your side marker
disgard the black wire going from teh side marker going into the car
get a new peice of wire, and tap it into the green wire and run it into the black wire going into the side marker.. dont[' touch the red, black wires taht aren't going into the side marker or the red going into the side marker. only cutting one wire and splicing one..
Ok i can give u the jist of it... Find the wires going to your side marker and you have to cut one of them.... Im positve its the Negative black wire.. Then connect the wire from the marker to the positive wire on the blinker. Thats the green wire i think. Make sure you cut the wire on the marker, dont just splice it or you will get a short. And you can either splice it into the green wire or just cram it into the connector like i did. This will cause your side markers to blink at the same time your blinkers do during the day. But when you turn your lights on your side markers will turn off when the blinkers blink..
Adam
Adam
Adam
Adam
when i say turn off i mean they turn off only when the blinker is on. Meaning they blink alternatly in relation to the blinker.
Adam
Adam
thanks,
Alex
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
doobadoo
Aug 15, 2015 06:43 PM
