Torque
Old Sep 2, 2003 | 08:30 AM
milellie111's Avatar
Torque
I have a 2000 Se Auto max. I just wanted to know what mod is best for adding the most low end tourque off the line??
THanks
Old Sep 2, 2003 | 08:36 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
THanks
the best low end mod that i have gotten so far would have been having the timing advanced and udp. everything else is better suited in mid and upper rpms.
Old Sep 2, 2003 | 08:38 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Cold Air Intake (instead of POP or hybrid), UDP, and yeah timing advance will help all-around. If you have the 17" rims, they're way too heavy for a 3.0 and cost a lot of performance. Getting some lighter 17's or ultralight 18" rims would help also. If you have the 16" rims you're in good shape.
Old Sep 2, 2003 | 08:40 AM
What is a UDP and how much would it cost to get the timing advance and where do i get a udp from??
Old Sep 2, 2003 | 08:43 AM
Cutler's Avatar
CAI is good, UDP does nothing on the autos(well almost nothing) and the 17s are heavy... Get some light 18s
Old Sep 2, 2003 | 08:18 PM
sloppymax's Avatar
udp is an under drive pulley. the most popular is made from unorthodox and be bough at custommaxima.com, eatricezone.com or stillen.com. im pretty sure eatrice has a better price. timing has to be done through a consult 2 which is exclusive to nissan, so if you know someone at a dealer then they should be able to hook you up. if not, it can be a major hassle. im auto and after the udp, i felt as though it was easier to come up to speed and the revs do climb quicker.
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
