Has Anyone Rewired 2k2 High beams to work independent?
Old Sep 7, 2003 | 12:47 PM
chinaonnitrous1's Avatar
Wondering if anyone with a 2k2/2k3 has rewired thier High beams to work independntly. Bascially, i want to flash my high beams without my HID's comming on...
Old Sep 7, 2003 | 05:17 PM
E55AMG2's Avatar
Wat
lookin into it now....
Old Sep 7, 2003 | 05:20 PM
LithiuMax
Trying to keep the HID's from dieing in like a year, eh? Hehe..
Old Sep 7, 2003 | 05:29 PM
E55AMG2's Avatar
Wat
Cannot be done, because the the relay for the Hi beams goes is the same relay for the HIDs. What would happen is if you wired it to use 4 relays instead of the 2 that are there, every time you hit the high beams the HIDs would turn off (this is what you want, but at night you will lose the HIDs if they are on, and there will not be enough illuniation). It would have to be re-designed to use 4-6 relays and alot of other things. Basically, making a separate circuit for each of the 2.
Old Sep 7, 2003 | 05:41 PM
OpTi's Avatar
http://www.vqpower.com/v2/modules.ph...article&sid=47
"2002 HID conversion (HID stay on when the high beams are on)"
Old Sep 7, 2003 | 07:21 PM
E55amg2. I was thinking the same thing about the relays. im at work (best buy) with my car in teh shop playing and flickering my hi beams, testign teh relays. I think it'll be much easier to just, make an independent relay bank setup. to click the hi-beams on and off, after i find the wire that comes from the headlight stalk. Just a pain in the *** to do. Id love to be able to hi-beam people without my HID's fickering.
Old Sep 7, 2003 | 07:22 PM
oooh Thanks for the reply !
Old Sep 7, 2003 | 09:48 PM
BigDogJonx's Avatar
Thats amazing, all this time I thought my wiring setup had this problem and there Nissan goes and does the same dumbazz thing on the 2k2's. But defientely no way of fixing it.
Dixit
Old Sep 7, 2003 | 11:40 PM
Dixit
stupid POS>
Old Sep 8, 2003 | 12:10 AM
E55AMG2's Avatar
Wat
dude, just re aim you HID's up a little and you can hit them with both the HID and the Hi beams...
Old Sep 8, 2003 | 01:42 AM
HitManSE's Avatar
Since I got the 2K2 headlight, I though I had this thing solved but for now I cant use my high beams either. The HIDs stay on when I falsh the high beams but the fog lights shut of while the high beams are on for some stupid reason I have HIDs in my fogs as well so no flashing unless I shut off the fogs then flash. Dumb if you ask me, its stupid little things like that, that really get on my nerves.
Old Sep 8, 2003 | 04:55 AM
2001SE's Avatar
do HID xenon bulbs die quickly?
Old Sep 8, 2003 | 06:51 AM
davidme's Avatar
they do if you turn them on and off all the time
i.e. keep then on when you are just running into the 7/11 or pumping gas etc.
Old Sep 8, 2003 | 09:16 AM
mingo's Avatar
just honk man... my hid stay on with my high beams, but when i flash both flash (when hid's are off).. my high beams are almost independent of the hid... u'll hafta use a relay man and rewire the light switches. they made it that way so people wouldn't leave their high beams on when they turn the car off with the lights still being one (when stuck in high beam position)
Old Sep 8, 2003 | 12:18 PM
TimW's Avatar
The silent but deadly Moderator
When I did my 2k2 light conversion, if you pulled the light stalk, they would flash the Highs only.. whereas pushing them would be both.
I only used a relay on the highs.. Ground was to the body and relay powered of the driver side high beam (+)
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
Blackwind
Aug 5, 2015 06:35 PM
kenc15
Aug 5, 2015 08:29 AM
