spark plugs
Originally Posted by andrew3616
Ok i have the factory plugs in my car. How often are you supposed to change them. What is the model number for the copper ones to fit my car? thanks
Not sure on the model number for those, but I'm running Bosch's in my car and they work wonderfully. I would change the plugs out around 45-50K miles....
Please use the search. It actually does work, so take advantage of it.
Spark Plug thread search
Originally Posted by Colonel
Geez, Now I am having to "squawk" this.
Originally Posted by Y2KSESteve
I use copper plugs and change them out every 10k miles.
Just get platinum plugs so you don't have to go through the pain of replacing them so often. Your stock plugs are platinum and the recommended replacement cycle is 100K miles, but many of us replace them between 45K to 60K miles.
NGK PFR5G-11 is the model number for the stock platinum spark plugs and Courtesy Nissan sells a set of 6 for $57.00. You can get them even cheaper on eBay where they go up for auction a few times every few weeks. It was worth it to wait for eBay availability.
Originally Posted by MannyNJ2k2max
wont our stock plugs last us 100K?
Originally Posted by Quicksilver
Hell no they won't...well, they will, but your car will not run as good as it should with newer plugs. I'll replace mine every year. That's just part of my yearly standard maintenance routine...
There is a difference between parts lasting long and them performing their best, so you have to ask yourself what kind of person are you......
Also, what kind do you use? I'm guessing not platinum if you replace them every year.
Thanks,
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
