Any recommendation on best shocks?
Old Sep 11, 2003 | 04:57 AM
FanaticMadMax's Avatar
I'm debating whether if I should get better shocks than the stock on my car since I like how it handles on turns and cornering but I hate that basketball bouncy when it hit on bad pavements. Any recommendation what brand of shocks I should get. I wasn't sure if Blisten or Koni would be good? I'm open to suggestions
Old Sep 11, 2003 | 06:04 AM
Todds_max's Avatar
Excellent question/point. I too am satisfiled with the overall ride and drive of my car now that I have the FSTB and RSB. My GLE actually remains pretty flat up to the limit of its turanzas. I was very suprised! Like you the only thing I wish for is more bounce control. The shocks just don't seem up to the task. I've scanned the stickies and have not found any real good info on a better replacement shock/strut assembly. I don't want to change the springs or anything else, just the shocks. Oh yea, the front SB could be a little stiffer to improve turn-in.
Old Sep 11, 2003 | 07:12 AM
chigga's Avatar
i think kyb agx adjustables are available for your car fanatic. they might need a lil modding but i know people that have them. i've heard the kyb gr2's are good too. i'm waiting on some adjustables for the 2k2-2k3's to come out..
Old Sep 11, 2003 | 04:10 PM
Kby agx adjustables? I haven't heard of one of those , is that adjust the valve of the oil flow to the shock how stiff or firm you want it?
Old Sep 11, 2003 | 04:29 PM
Y2KSESteve's Avatar
I personally would recommend Tokico Blues.
Old Sep 11, 2003 | 04:52 PM
skyjay617's Avatar
If you have stock springs, i think the KYB GR-2s will be good enough. Other adjustable shocks, such as koni and kyb agx, they are the best for lowering springs. If you want to get lower in the future, i suggest u get the Kyb agx or Koni(if u have money). the good thing about koni is, it is not only can adjust the rebound rate, it can also adjust the height of your car, i think u can lower ur car about 1/2 to 1 inch. u can't go wrong with Koni's performance.
hope this helps
Old Sep 11, 2003 | 05:01 PM
Luquire's Avatar
where is a good place to buy koni. also i have heard that you have to remove the spring and shock everytime you want to adjust things
Old Sep 11, 2003 | 07:14 PM
redstradic's Avatar
why would you recommend toks over the gr2s, thanks
Old Sep 11, 2003 | 07:40 PM
Cdriven's Avatar
I was out looking at tirerack.com today and saw that they have Koni sport shocks for around $130 each. I was actually looking for the KYB GR-2 for my 03 SE, but the only shocks the site showed that fit my 03 max were the Konis. I couldn't tell you if that's a good price or not...
Old Sep 12, 2003 | 05:16 AM
MaxSE03's Avatar
Yep, you have to remove the rear struts every time you want to adjust them. The front can be done on car.
Another thing that most people do not realize, the Koni is only an insert. You have to modify the factory strut housing to make them work.
Old Sep 12, 2003 | 04:58 PM
EGADS!!! Sounds like it's a pain to do if i wanted to adjust the shocks. As for Koni, I didn't know that you have to modify the strut housing. I was checking out with Koni.com, their website is useless for info.
Old Sep 12, 2003 | 05:57 PM
Maximus03SE's Avatar
I have KYB GR-2's on my '03 SE. Perfect strut for what you're looking for. Took the floaty feel out of bumps, and only slightly stiffened the overall ride.
Highly recommend them for anyone wanting to keep a near stock ride without the float over dips/bumps
Part Numbers: 334265, 334266, 341271 x 2 (rears)
I got them new on eBay for $279 (shipped price)
Old Sep 12, 2003 | 06:07 PM
maximadave's Avatar
detailerdaveb@gmail.com
Old Sep 12, 2003 | 06:12 PM
Igor911's Avatar
i have the eibachs w/ tokicos blues and it sux! Ride is sooo floaty like WHOA...makes me wanna fall asleep some times on highways.
I'm thinking of getting coil-overs...
Old Sep 13, 2003 | 07:54 AM
kwd2kSE's Avatar
Agreed-KYB GR-2. Igor911, they also work well with my Eibach's
Old Sep 13, 2003 | 11:21 AM
Tony Fernandes's Avatar
I have the KYB GR-2s with Maxspeed springs. Couldn't be happier.
Tony
Old Oct 20, 2003 | 01:57 PM
bobicg's Avatar
Just replaced factory equipment with a set of kyb gr2's shocks and struts, WOW what a difference in handling, its not the same car. Ride quality is a little rougher but for the difference in body roll and stability on all cornering is great, especially if you like to occasionally (LOL) take it to the limit. I would definitely recommend this mod.
y2k GLE auto
Old Oct 20, 2003 | 01:59 PM
NT2SHBBY
Tony
10chars
Old Oct 20, 2003 | 02:17 PM
GreekMaxima's Avatar
i just send money for Tein lowering springs for $150 shipped from AltiMax!
so now i have to buy shocks/struts... i hear good reviews about tein/kyb but i want some more information guys... thanks!
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
