Clearing up headlight housings
Old Sep 11, 2003 | 01:43 PM
releasedtruth's Avatar
rilla dope
Question for you guys, after a few years the clearness of the headlight housings isn't as good as before. I've done the wet sand thing on other cars, but wondered what you recommend for the max. Plastic polish maybe?
Vito
Old Sep 11, 2003 | 02:37 PM
Y2KSESteve's Avatar
All I use is Meguiars #26 wax. Two applications and my headlights look new.
Old Sep 11, 2003 | 03:34 PM
beejo's Avatar
what's is dat wax? what color is bottle of it?
Old Sep 11, 2003 | 04:06 PM
Y2KSESteve's Avatar
It's an off-white color.
Old Sep 11, 2003 | 10:25 PM
thomasd cook's Avatar
I've got a haze discoloring on mine. How can I clear that up?
Old Sep 11, 2003 | 10:37 PM
Triple8Sol's Avatar
I miss the .org!
Do you have 2K2-2K3 HID headlights?
Old Sep 11, 2003 | 10:45 PM
02MaximaSE's Avatar
Use 3M PLASTIC POLISH.. Theres a TSB on it in the Altima.net forums... Just follow those procedures.. Mine are good as new
http://www.altimas.net/tsb/
Old Sep 11, 2003 | 10:57 PM
Uconn411's Avatar
Q. for you guys. My HID headlights look fine off, but when they are on @ night, you can see a sort of white haze on the lens, and I'm not sure if its on the inside or outside. I have of course tried numerous products to clean the outside. Is the haze you guys are referring to some sort of dis-coloration on the outside of the headlight? I'm afraid that this 3M product might scratch up the headlight.
Old Sep 11, 2003 | 11:00 PM
02MaximaSE's Avatar
the plastic polish wont scratch up your headlights.. I've used them for a long time now. And they are fine.. the dealer also uses them for the same problem.
Old Sep 12, 2003 | 12:12 AM
My headlights are 2K. I'll try that plastic polish.
Old Sep 12, 2003 | 11:01 AM
NizanDrivn's Avatar
I think there is a TSB for the haze problem, though I'm not sure what the dealer does to clear it up...
I think the haze is on the inside, I've actually buffed mine with a polisher
so is the haze inside or out?
Old Sep 12, 2003 | 11:10 AM
kcowden's Avatar
I have the same problem.... the haze is on the inside of mine. Has anybody gone to the dealer for this and what happened??? Thanks
Old Sep 12, 2003 | 01:08 PM
02MaximaSE's Avatar
the dealer says its "typical wear and tear" and doesnt cover it. The TSB is for their reference on how to get rid of it. If its on the inside that would indicate a moisture leak.. which is grounds for anyone with warranty to replace.
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
