MAF replacement at 4,000 on '03 SE
Old Sep 13, 2003 | 09:05 AM
jay beede's Avatar
My maxima is going in to have MAF/ECU replaced (just 4,000 miles on my maxima). Anything I need to know or watch out for regarding MAF/ECU replacement? Rumor is they won't let me have the old MAF even if the new one is "worse".
Old Sep 13, 2003 | 09:14 AM
† ErV †
MAF is a common problem... but why would they touch the ECU? Unless if they are resetting it, there is no need to bother with it.
The less you floor it the longer it should last. I think. Other than that it's a random thing.
Old Sep 14, 2003 | 08:55 AM
studman's Avatar
Make sure the new part number is 22680-AM600. Also, take a copy of the TSB for Lack of Power with you. It's available on my homepage.
And as for how-not-to-blow-them, we're still figuring that out, because I blew the 22680-AM600 even after the ECU reprogram. So they are not 100% solid, but they appear to be more reliable than the 22680-6N200 or 22680-6N201.
Old Sep 14, 2003 | 02:19 PM
Cdriven's Avatar
I'm curious, did your max come with the newer MAF (22680-AM600 ) or one of the older ones (22680-6N200 or 22680-6N201)??
I have a '03 SE and sometimes it just drags...doesn't want to go unless I floor it.
Old Sep 14, 2003 | 09:56 PM
jay beede's Avatar
Is the part number visible or does the engine cover need to be removed?
Old Sep 14, 2003 | 10:02 PM
Maximam's Avatar
Look in the door and tell me the build date of your car please?
Old Sep 15, 2003 | 11:00 AM
studman's Avatar
All the 2003s came with 22680-AM600. The part number is printed on the MAF tube assembly. If your stock airbox is still installed, it's harder to see it. But look where the filter goes. There is an angled round tube coming off the filter box towards the TB. That's the MAF tube. The writing on the tube faces the front bumper, so it's hard to read if the airbox is installed as the filter-area of the box blocks your view.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
