Dakota Digital installed....pics....
Old Sep 14, 2003 | 09:34 PM
PoLo's Avatar
2-Wheelin it...
i know this should go in the audio section, but i seem to enjoy this section more than that one...just finished installing the dakota digital voltage gauge....this is easy than installing clears....well maybe not that easy, but in that level. okay, a FSTB, cause it does take a little time. instructions say to tap it to any accessory wire. comes with a warning meter. mine is set at 11.8v
def. needing this for any audio system, i can understand whether i'm getting heat saturation or if my battery or alt. are dying. anywayz, just throwin a few pics up...enjoy
all pics located here
Old Sep 14, 2003 | 09:38 PM
LithiuMax
Where can I get that and how much does it cost? How hard was the install?
Old Sep 14, 2003 | 09:43 PM
PoLo's Avatar
2-Wheelin it...
dakota digital website...$89...if you want to save loot, you can get the stinger meter for about half, BUT it doesn't fit in the pocket, so it's of no use to me. fits in a gauge pod, if that's your interest.
install was a J-O-K-E...since i need it to turn off and on with the car, and i needed an accessory wire, i tapped it into my cig. adapter. just used wire taps and popped them in. getting to the cig. adapter wires was JUST as easy. then just reaching up behind and running the wires through, 16ga wire...took me no more than say, 20 minutes.
Old Sep 14, 2003 | 09:53 PM
BigDogJonx's Avatar
Nice...... I get my voltage off my turbo timer now.
Old Sep 15, 2003 | 06:06 AM
PoLo's Avatar
2-Wheelin it...
cheater...
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
SCCA Solo2
Nov 5, 2000 10:51 AM
JJW95SC
Oct 23, 2000 11:37 AM
