Pads rubbing against the rotors
Old Sep 21, 2003 | 09:16 PM
steelymatt's Avatar
Guys,
I have metal master pads. They were squealing a lot so I added some anti-squeal compound between the pads and the shims. Now my car feels a lot slower. Is it possible that the pads are rubbing against the rotors? My rpm vs. speed is pretty much the same and my gas mileage hasn't really changed at all.
Thanks.
Old Sep 21, 2003 | 09:57 PM
E55AMG2's Avatar
Wat
most likely, they are rubbing in the rear. It could be 2 things, you have shims on the pads and reinstalled the factory shims (2 sets on each pad), or the rear pads are too thick and you gotta grind them down or wear them thinner.
Old Sep 21, 2003 | 10:49 PM
jonbth's Avatar
Anti squeal compound won't make your pads rub against the rotors, they just keep them from vibrating.
Old Sep 21, 2003 | 10:59 PM
E55AMG2's Avatar
Wat
yep, thats correct
Old Sep 21, 2003 | 11:23 PM
iLLin-2k1's Avatar
Anti-squeal goes on the back of the pads... they don't even touch the rotors. But I might have misunderstood what you meant. Oh well my two cents!
Old Sep 21, 2003 | 11:53 PM
steelymatt's Avatar
Maybe you misunderstood. I'm wondering if by putting the compound between the pads and the shims like you're supposed to, it creates too much space and pushes the pads against the rotors.
Old Sep 22, 2003 | 01:09 AM
E55AMG2's Avatar
Wat
As stated earlier, They may have not taken out the OEM shims or the pads may be to thick. I got the stealin pads (i know they didnt put the shims in,cause they gave em to me in a box), and the rears were too thick. I had to get them sanded a bit for them to work right. Otherwise they just rubbed until they smoked, which is BAD.
Old Sep 22, 2003 | 04:07 AM
wdave's Avatar
If they're rubbing enough to make you slow they'll get really hot when you drive, you should be able to feel (carefully) the heat.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
