Need Help on 1320 ECU Code
Old Sep 29, 2003 | 04:02 PM
sensabible's Avatar
My Service Engine Soon light came on today. I have a 2000 GXE and I took it in to have them see what exactly it was. What they found was the 1320 code something to do with the ignition. I had to make an appointment to look further into it because they were not too sure what the real issue is. Does anyone know what this could be and how much this may cost me in the end?
Thanks for any help.
Sensabible
Old Sep 29, 2003 | 04:13 PM
UMD_MaxSE's Avatar
Got Bent?
your ignition coils are bad...
Old Sep 29, 2003 | 05:36 PM
maxgsxr1
Sensabible
replace all 6 coils for starters(very common on 00 max)01 is updated style coil. and new plugs too if over 60k while removing coils.......coils about 100$ each plus maybe an 1hour labor.
Old Sep 29, 2003 | 05:49 PM
sensabible's Avatar
Is there a way to find out if it is just one coil or is it best to replace them all? I would rather not have to spend $600.00 to replace all of them if it is just one.
Thanks,
Sensabible
Old Sep 29, 2003 | 05:54 PM
UMD_MaxSE's Avatar
Got Bent?
$600? Contact Dave Burnette and I think he can get you all six coils for half that or so...
Old Sep 29, 2003 | 06:32 PM
sensabible's Avatar
Does Dave Burnette have an email or a user name on this site?
Thanks for give me this information. Is there a specific manual that shows how to replace these coils and plugs your self?
Old Sep 29, 2003 | 07:12 PM
maxgsxr1
Thanks,
Sensabible
if you replace one coil ,that coil will have the the most resistance in the system and the next coil with least resistance will be faulty next until all are bad.i,ve seen it many times. just replace all 6 and shop around for cheapest coil prices..........
Old Sep 30, 2003 | 04:36 AM
UMD_MaxSE's Avatar
Got Bent?
look at the sticky threads at the top of this forum... his contact info is in there... Replacing coils and plugs is easy... do a search in this forum for the how-to
Old Sep 30, 2003 | 08:16 AM
twllin's Avatar
Replace all the coils please theyw ill all eventually go bad they have them on ebay i got them for 170 shipped to my door i can find them for you again if u need them Pm me on yahoo messenger my screen name is twllin
Old Sep 30, 2003 | 08:28 AM
OSoFast's Avatar
Get your ecu scan, it will tell you exactly which one is bad, and then you can go from there. I had the same problem a while back, bought a scanner, scanned it and it show that my #6 coil is misfiring. saves you the headache and money by trying to replaced all six of them. Good luck!
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
