Sub box question
Old Sep 29, 2003 | 10:35 PM
Prodigy's Avatar
Sub box question
How do you guys with systems keep your box from moving around the trunk? I straighten them out constantly, maybe I take turns a little too quick but even after a 5 minute drive the carpet is all shifted and the subs are rubbing against the back of the trunk.
I need to find a good way to secure them so they stop slamming around back there. Would I be able to use the hooks for the cargo net to secure the box or will it be too heavy?
-Tim
Old Sep 29, 2003 | 10:44 PM
SEmy2K2go's Avatar
Go BUCKS!!!
-Tim
I think there have been a few postings regarding this issue, but one good way is to secure some velcro strips on the underside of your enclosure or some "L" brackets possibly.
Old Sep 29, 2003 | 10:45 PM
LithiuMax
Use velcro if the box is not too heavy. You said "boxes" though, do you have 2 separate boxes for 2 separate subs? If so, that isn't very good.. anyway, you can also use L-brackets, but you cannot move the box around unless you unscrew it out of place.
Old Sep 29, 2003 | 10:56 PM
Prodigy's Avatar
I have one box with 2 subs, Its pretty heavy, I'd say close to 100lbs. I was thinking about using L brackets but what should I screw them into? The board over the spare or what?
Old Sep 29, 2003 | 10:58 PM
KLOOGY's Avatar
L33t BMW Drivah
Problem solved
Old Sep 29, 2003 | 10:59 PM
LithiuMax
Prodigy, screwing it into the board would work fine. Good luck.
Firing towards back of car = better than firing upwards. But, you do have way more trunk space left, and it looks nice...
Old Sep 29, 2003 | 11:00 PM
Prodigy's Avatar
Damn I'm jealous...If you don't mind my asking how much did that run you? Did you do it yourself of have it done?
Old Sep 29, 2003 | 11:03 PM
KLOOGY's Avatar
L33t BMW Drivah
Well, I got it from my buddy, who sold his Max.... Cwally. He paid about 1k just for the labor of the box and amp rack.. Check out this page so you can see all the dynamat they used and the install.....http://www.cardomain.com/member_page...200767&page=13
Now as far as the price of the equipment...well:
2 - 12 inch Eclipse Aluminums
1 - 800 Watt 4 channel Fosgate
1 - 800 Watt 2 channel Fosagte
1 - Chrome Stinger 1 Farad Cap
Lots of Dynomat, and I still get rattle
Old Sep 29, 2003 | 11:54 PM
WildmanAL's Avatar
Well I solved the problem by building a square box with 1X4's. Then stretching carpet over the whole thing. It's as wide as my box and keeps it snugg up in the trunk. I can easily lift it out and the box can slide out.
These are 12" Kove Armageddons. They weigh a lot with the box and I was still having a problem with it sliding around. After one time taking a corner too sharp in my old max and almost ripping my RCA jacks off I decided to secure it this way.
Old Sep 30, 2003 | 11:03 PM
KLOOGY's Avatar
L33t BMW Drivah
But you now have no trunk ?
Old Sep 30, 2003 | 11:15 PM
MaxVader's Avatar
For now I use bungy cord.
Old Sep 30, 2003 | 11:16 PM
WildmanAL's Avatar
Come on Kloogy don't rub it in that I can't affort a custom set up like you. I have more than what it looks that I have in the picture. It's about 16" from the sub box to the car. Just enough for old women and children that I pic up on the block. j/k
Old Oct 1, 2003 | 12:07 AM
KLOOGY's Avatar
L33t BMW Drivah
...thats kool bro....as long as you bump....its all that matters !
Old Oct 1, 2003 | 01:10 AM
MyownNismo's Avatar
Future Camaro SS owner
Oh yea check this out. Mine also takes up no space and doesn't move around and it's not bolted down. The cargo net holds it in.
Made it myself. I am a MECP installer. Got new setup going to start, got another 10" so might sell the box.
Old Oct 1, 2003 | 05:49 AM
asu174's Avatar
Clay Aiken has fancy genitals
I bought two "t" brackets and drilled them into the lip on the back of the trunk. Then I drilled a 2x4 into the bottom of my box to compensate for the angle of the trunk floor.
Old Oct 1, 2003 | 06:21 AM
MannyNJ2k2max's Avatar
mines so heavy it doesnt move around at all
(kicker amp bolted in back of a q-logic w/ 2 10's mtx 6000)
Old Oct 1, 2003 | 07:13 AM
maxamillyon's Avatar
so kloogy when are you going to sell your car?
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
bumpypickle
Sep 20, 2015 08:22 AM
Stagnet04
Sep 14, 2015 11:28 PM
