Low alternator voltage output??
Old Oct 7, 2003 | 05:45 PM
spirilis's Avatar
I noticed yesterday with an analog voltmeter that my charging system voltage sits around 13.5-14V, not 14.0-14.5V like it should... I took the car to Advance Auto and had them hook up their battery/alternator tester (i.e. the one with 2 battery clamps and an inductive pickup they put around the alternator output wire), and it reported a regulator voltage of 13.89V and roughly 23A maximum output. WTF!???
I'm removing as many of those "hyperground" wires as I can, in case that's what's causing it... or at least remove the wires nearby the alternator.
Any ideas?
Old Oct 7, 2003 | 06:31 PM
spirilis's Avatar
hmm interesting, alldatadiy.com's manual says:
ALTERNATOR OUTPUT
Rated output amps Test output @ 2500 eng. rpm
110 amps 85 amps 13.5volts
so I guess 13.5-14.0V is OK... (battery voltage is around 12.5 with lights on)
Old Oct 7, 2003 | 11:48 PM
Igor911's Avatar
mine is at 14.3 when car is on with out radio on
Old Oct 8, 2003 | 03:52 AM
spirilis's Avatar
hmmm OK... I guess I won't worry about it for now--BTW, what's your battery voltage without the engine running? (mine's roughly 12.4-12.5)
I really should get a gauge pod and stick a voltmeter gauge in there for the hell of it...
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
