Just washed my in-cabin microfilter...
Old Oct 8, 2003 | 05:47 PM
TXT-1's Avatar
Man that thing was dirty. There were bits of leaves, pine needles and the expected dust in the filter. Wasn't sure what kind of soap to use to clean it, so I used some regular old laundry detergent and let it soak in there. Hopefully my car won't smell like @ss anymore. If it does, then I know it's my feet.
Old Oct 8, 2003 | 05:50 PM
fishhouse's Avatar
where is that anyways? and how hard is it to get to and reinstall?
Old Oct 8, 2003 | 05:53 PM
TXT-1's Avatar
It's located behind your glovebox. Just remove the glovebox latch, then the glovebox itself. Complete directions with diagrams can be found at http://www.courtesyparts.com/instruc...binfilter.html
Old Oct 8, 2003 | 06:00 PM
fishhouse's Avatar
great thanks!
Old Oct 8, 2003 | 06:03 PM
TXT-1's Avatar
Just make sure your's is the washable kind. I don't think anything before 02 or 03 is washable. It will say on that sticker inside the glovebox.
Old Oct 11, 2003 | 04:51 PM
jonbth's Avatar
I believe if it's one piece it's washable. I had a one piece on my 02 SE. I went to the dealer and bought the more expensive charcoal filter which is a two piece filter which is not washable.
Old Oct 11, 2003 | 05:30 PM
trey
When mine gets dirty, i'm gonna pull it out and not put another back in, i mean whats the point? i drive with my windows down all the time anyway
Old Oct 11, 2003 | 06:56 PM
fishhouse's Avatar
what is the point of this thing anyways? it just filters incoming air? air from the ac/heat or what?
Old Oct 12, 2003 | 12:46 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Great Idea for Fall Cleaning!! Just cleaned mine! WOW was that thing dirty! Leaves, Dust, Bugs. Not hard at all just 6 lil' bolts and two push clip! Viola' clean air.
Old Oct 12, 2003 | 02:39 PM
fishhouse's Avatar
ok...i took off the glove box, removed the filter cover and...THERE IS NO FILTER! what is up with that?
the box is just empty! i can see the grates up int there form the cooling unit, guess...but no filter - just an emtpy box! whole bunch of leaves in there too!
maybe that is why my car smells all the time!
anyone know how much one of these filters runs (the cheaper washable kind)? part #? can you get one from anywhere besides FNND?
Old Oct 12, 2003 | 02:45 PM
fishhouse's Avatar
ok...Courtesy has a carbon filter for $45! i'll just go without one if they are all that expensive!
anyone know anything about cheaper ones (or generics)?
Old Oct 13, 2003 | 10:49 AM
fishhouse's Avatar
is the washable one "carbon" or is that the more expensive one?
Old Oct 13, 2003 | 10:52 AM
maximadave's Avatar
detailerdaveb@gmail.com
I washed mine last night. Damn that thing was dirty. A/C doesn't stink no more!
Old Oct 13, 2003 | 01:31 PM
exunaja's Avatar
I envy myself now.
not only I have a y2k, about 33 less hp, missing a HID and also no washable in-cabin microfilter that come with the car.
I need to purchase the carbon activated filter for $45. hmmm
Old Oct 13, 2003 | 01:59 PM
fishhouse's Avatar
agreed! pretty sh*tty, huh?!
Old Oct 13, 2003 | 03:00 PM
Rob'sAE's Avatar
You're Faster, I'm Better
Is there a way to get ahold of a washable filter? I wouldn't mind paying upwards of $50 if I knew it was washable. Is it something that is standard on all or most all 2k2/3's so that I might get one from a junk yard?
Old Oct 13, 2003 | 03:33 PM
jeepik's Avatar
man i just took mine out boy was that thing dirty..didnt wash it yet, but there was a lot of dirt dust and sticks and leaves in there
Old Oct 13, 2003 | 03:52 PM
Rob'sAE's Avatar
Another question, does anyone know of a good way to clean the coild inside of the filter box? I can see some "stuff" on the coils on the inside but have no idea on how to get in there and cleaning it, or what to use to clean it. I am thinking of a toothbrush on a long stick with some bleach water. Any ideas? Might I mess something up or put a smell or residue in there that I would be better off not having?
Old Oct 13, 2003 | 06:38 PM
ppetruccelli's Avatar
It helps protect cooling and heating system
I would keep the filter in the car as long as it doesn't stink or block airflow. The filter keeps dirt (leaves and dust which turns in to mud) from getting into your A/C condenser unit and heater core. Either part can clog up. It happened to me on another one of my cars and I had to remove the heater core and have it cleaned (alot of work or very expensive). KEEP THE FILTER IN!
Old Oct 13, 2003 | 06:40 PM
I removed the blowed fan for better access (very easy - 3 screws) and put the hose from my shop-vac in there. The vacuum cleaned it out pretty nice.
Old Oct 13, 2003 | 09:24 PM
PHATMAN5050's Avatar
Originally Posted by exunaja
I envy myself now.
LMAO I was thinking the exact same thing!
Old Oct 14, 2003 | 06:49 AM
Rob'sAE's Avatar
Sweet. I didn't want to take something apart and not be able to put it back together again. Now I can keep that sucka supa kleen!! My car is going to smell like new leather for a very long time.
Old Oct 14, 2003 | 11:37 AM
exunaja's Avatar
Forgot a couple other thing, navigation, 6 spd manual, and also painted splash guard, and many other things aagggghhhhh.. btw I don't miss the bose system.
Old Oct 14, 2003 | 01:03 PM
ajohnsonnefn's Avatar
i dont have one either....theres all types of cugma in there, are they not on the 2ks?
Old Oct 15, 2003 | 06:17 AM
jgibson146's Avatar
Just washed my filter, it had alot of crud in it only a year old. Don't disconnect the yellow plug on the top of the glove box when accessing filter. Just pull out the two fasteners on the base. Washing is cheaper.
Old Nov 9, 2003 | 07:11 PM
Rob'sAE's Avatar
Why shouldn't you disconnect the yellow plug?
Old Nov 9, 2003 | 07:34 PM
fishhouse's Avatar
are you serious? because it is a plug to your airbags!
not sure if it will cause them to go off or just mess them up some other way....JUST DON'T UNPLUG IT!
Old Nov 9, 2003 | 08:02 PM
maximadave's Avatar
I finally replaced it.....
Old Nov 9, 2003 | 09:47 PM
KLOOGY's Avatar
L33t BMW Drivah
I just bought one yest, so we shall see what mine looks like after a nice month of fires in So Calif...
Apr 16, 2020 05:15 AM
carid
Sep 17, 2015 05:00 AM
Bonka
Sep 14, 2015 11:18 PM
adamgalazka
Sep 9, 2015 03:39 PM
