ques about my my max
Old Oct 9, 2003 | 10:54 AM
...'s Avatar
ok i recently found my self in a new 2002 max like 2 months about 2 months ago. it full loaded, 6speed, leather, bose, sunroof and such.... and i was wondering.... with all these Shlt how come it doesnt have traction control???? wats up with tat?? and i was wondering is there a great difference between max with traction and the ones without...??? is there more safty things with the ones with traction??just wondering....
Old Oct 9, 2003 | 10:56 AM
Ben's Avatar
Ben
Somebody correct me if I'm wrong, but I don't think traction control was an option on manual transmission.
Old Oct 9, 2003 | 11:17 AM
Audtatious's Avatar
Bandwagon Lover
Traction control in a manual is called "feathering the clutch".....
Old Oct 9, 2003 | 11:23 AM
NT2SHBBY
this is correct, BUT they did have option for HLSD, which IMO is FAR better than any traction control system
Old Oct 9, 2003 | 12:16 PM
E55AMG2's Avatar
Wat
The maxima TCS on the auto is simply there to cut wheelspin. Anyone who has taken their car to the track knows that you need wheelspin for a good launch. But, wheelspin in moderation, too much and your run is toast. The TCS on the autos kills it completely on the sticky track surface. With the manuals, just use the clutch appropriately and you will be sruprised.
I think that ... is referring to a stablilty control system more like VDC. The fact of the matter is, with a FWD car and our weigh bias, it will end up makin things worse.
MaxZ71's Avatar
just wanted to add a 6-speeds dont have traction control.
Old Oct 9, 2003 | 12:18 PM
Ben's Avatar
Ben
I may be missunderstanding, but I think traction control and limited slip differential a different sorts of things. LSD is for distributing power among the wheels effectively during acceleration (particuarly in corners.) Traction control applies to all 4 wheels and uses the brakes independantly to bring the car back under control when sliding or spinning.
LSD or feathering the cluth only helps reduce wheel spin during acceleration from uneven traction. It does not help when spinning or sliding in the rain as traction control would.
Can somebody correct this?
Old Oct 9, 2003 | 12:27 PM
Igor911's Avatar
They do, however have HLSD aka "Limited Slip"
Old Oct 9, 2003 | 01:23 PM
Craig2kGLE's Avatar
If your car has the original tires on it, buy new ones. You'll feel like you have installed traction control.
Old Oct 9, 2003 | 03:03 PM
02MaXiMa_GLE's Avatar
My GLE runs great in the snow with the TCS on. It also works at highway speeds - 80MPH+ on wet or slippery surfaces, but it is a bit SLOW to engage.
Bottom line: my car is better
G
Old Oct 9, 2003 | 04:06 PM
EddiexAhn's Avatar
i was actually wondering if it was possible to install traction control in my 2k2 SE. the winters up in syracuse NY are HARSH and i got into an accident last winter b/c of all the damn snow.
i have the HLSD but didn't do much for me climbing hills and such in the winter. even feathering the clutch wasn't good enough. so just wondering
~eddie
Old Oct 9, 2003 | 04:09 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
~eddie
I don't think it can be done with a manual. There are too many variables that the ECU (clutch, clutch engagement vs. RPM output) doesn't control, and the sensors would have a hard time trying to keep up...
Old Oct 9, 2003 | 09:49 PM
Unless you have a VW Jetta... even the manuals have TCS enabled!
Snowtires on some steel wheels should solve the winter worries, eddie...
G
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
followthadollar
Sep 27, 2015 01:06 PM
