Will these fit a 5th Gen??
Old Oct 10, 2003 | 10:43 PM
NYC2SD's Avatar
Will these fit a 5th Gen. I believe the offset is 40mm.
Wheels
Old Oct 10, 2003 | 11:10 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Wheels
good question...i would think they could fit but if u do get them show some pics thanx
-J
Old Oct 10, 2003 | 11:11 PM
MaximaDisciple's Avatar
http://forums.maxima.org/showthread.php?t=254778
Old Oct 11, 2003 | 10:25 AM
ManualMaxima's Avatar
5th Gen till she dies!
i would not try it. I have a 4th gen and i bought some 40+ offset. They did not fit. So i tried tem on my dad's 5th gen. They for the back, but not the front. And you will either have to get a spacer and new wheels studs, or wheel adaptor whohc it would probely just be worth it to get another set.
Old Oct 11, 2003 | 10:26 AM
oh sorry, if they are maxima wheels i would thikn they woulf fit no problem. I though they were going to be after market. i think pretty much all maxima wheels fit other maxima's.
Old Oct 11, 2003 | 10:35 AM
NT2SHBBY
the lug pattern is fine...the issue is the offset which isn't 40mm, I am pretty sure it is 30mm, which is too low...the lowest u can go is about 35-38mm...
the rears will rub, especially if you are dropped
Old Oct 11, 2003 | 10:56 AM
asu174's Avatar
Clay Aiken has fancy genitals
The offset is 40mm (read the auction and also look at pics of the wheels).
Also, they will fit, HOWEVER, I think the tires will rub because they are too big.
Old Oct 11, 2003 | 10:59 AM
NT2SHBBY
Andy...2k2nyc runs 245/45/18's with H&Rs and no rubbing
I am still pretty sure the offset is what kills these wheels.....
Old Oct 11, 2003 | 11:51 AM
all i know is that i had some rims with the 40 offest and they did not fit a 4th or 5th gen.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
