maf sensor replacement tools
Old Oct 11, 2003 | 03:44 PM
ChromeSE5's Avatar
So I went to pepboys this morning (BTW i saw a lowered 2k2 or 2k3 from rpm motorworks in chino hills, just wondering who you are and nice rims... i parked in front of you) and asked for that hex tool to remove the MAF sensor. They didnt have it. I go to Kregan, they didnt have it. Then I went to a nissan dealership and they dont sell the blasted tool. Anyone know where i can get one? Imma try cleaning my MAF before i go out and replace it. Thanks. I might ask Dave B on monday if he sells the tool.
Old Oct 11, 2003 | 04:01 PM
JodyBerry's Avatar
I used a pliers and it was pretty simple. The threads are fairly large so it'll unscrew within a few turns. I didn't use needle nose pliers, I used regular pliers with a flat edge.
If you have a problem, e-mail me and I'll send you a photo.
Bill
Old Oct 12, 2003 | 01:13 PM
MaxVader's Avatar
Should I try cleaning the MAF before replacing. And what to clean it with?
Old Oct 12, 2003 | 01:16 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
its either a 20 or 25 security torx bit. just use that and a bit driver and it will come right out. i would personally recommened using electronic parts cleaner because it will clean the sensor and also is safe for the plastic that surrounds it.
Old Oct 12, 2003 | 02:36 PM
ChromeSE5's Avatar
so where do i get it?
thanks
Old Oct 12, 2003 | 02:53 PM
sloppymax's Avatar
thanks
you should be able to get it any sears, local hardware store or even lowes or home depot. it might be a part of a kit of torx bits and screwdriver bits. just make sure its the security one because the regular wont work.
Old Oct 15, 2003 | 12:59 AM
ChromeSE5's Avatar
Thanks fellas. Well, I just got some pliers and twisted the crap outta the screws. I replaced them with regular screws.
It gave me a chance to clean the MAF and damn... it worked. My car is back to normal. There was so much dust particles that everytime I ran a Q-tip over it, the Q-tip came back with some dirt. I sprayed it with TB cleaner directly at full blast. I hope I got most of the crap out.
Old Oct 15, 2003 | 04:52 AM
sloppymax's Avatar
not what i would have used to clean it with but good to hear that the car feels better. hopefully it will not be an issue anymore.
Old Oct 15, 2003 | 05:58 AM
MaScott's Avatar
Just wondering... - were you able to actually take the MAF out of the assembly or just turned it to get access to the metal leads?
When I cleaned my TB, I tried to pull MAF out to clean, and could not do that, so had to turn it 180 degrees...
Old Oct 15, 2003 | 06:43 AM
JodyBerry's Avatar
The MAF sensor is inserted into the black tube with an "O" ring, so if you would have kept twisting and pulling up, it would come out (obviously AFTER you took the screws out!!).
Bill
Old Oct 15, 2003 | 07:18 AM
MaScott's Avatar
I did try turing and twisting it (of course, with screws out), and pushing it out but I was afraid I'd brake something. So, not knowing the price I am risking, I decided to leave MAF in the tube.
Old Oct 15, 2003 | 08:19 AM
ChromeSE5's Avatar
Take two flat head screw drivers and ply out each side at the same time. Sounds difficult but its easy.
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 19, 2015 09:45 AM
