2k Max is jumping at 1700rpm
Old Oct 13, 2003 | 01:49 PM
ppetruccelli's Avatar
My car is irratic when the rpm's are held at around 1700rpm. Is there a TSB for this, or is it normal. I never noticed it before, because my car is automatic and rarely sits in that rpm range. Anyone else have this problem? How did you fix it?
Old Oct 13, 2003 | 01:54 PM
spirilis's Avatar
I'm not sure if the Fuel Cut TSB pertains to this, but according to the shop manual (viewed through alldatadiy.com), this is normal-
If the engine speed is above 1,800 rpm with no load (for example, in neutral and engine speed over 1,800 rpm ) fuel will be cut off after some time. The exact time when the fuel is cut off varies based on engine speed. Fuel cut will operate until the engine speed reaches 1,500 rpm , then fuel cut is canceled.
NOTE: This function is different from deceleration control listed under "Multiport Fuel Injection (MFI) System".
Old Oct 13, 2003 | 02:32 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What do you mean erratic? If you slowly raise the rpm to 1700, it suddenly JUMPS to 2000+rpm, then you slightly let off and if falls below 1000rpm?
If so, sounds like the FUEL CUT issue, however I've had the TSB done and it's not really improved.
Autos will have the same problem, but unless they're in neutral or doing a brake stand, they won't notice it.
I find when I try and hold anywhere between 2000-3000rpm, the exhaust flap keeps popping open or slaming shut causing my RPM to bounce around. It takes a very slow gentle touch to hold a RPM now with the TSB done, where as before it was impossible.
Old Oct 13, 2003 | 02:53 PM
This sounds like the condition my car is experiencing. It does it when it is in park, or in first gear on a flat surfuce (no load). Thanks for the help! It good to know that I don't have another problem
Old Oct 13, 2003 | 02:57 PM
I can actually hold my car at 1700, but then the rpms drop to 1000 and jump back up, contuniously repeating the same thing. From the last post, I believe that this is normal. Apparently, if the car has no load it is natural for it to do this (in park, neutral, or light load). Thanks for the info though!
Old Oct 13, 2003 | 03:20 PM
IceY2K1's Avatar
You know....I've read that a dozen or so times before and NEVER associated the two.
I'm pretty sure that's been my "gripe" all along. Damn Nissan not wanting me to do clutch dumps.
Now to figure out a way to defeat it, since auto VQ30 and VQ35 guys launch below 1800rpms, but us manual VQ30 guys need those extra rpm to get out of the hole.
Old Oct 13, 2003 | 05:02 PM
spirilis's Avatar
Note the wording:
I'd imagine if you rev it up fast, and then drop the clutch, you can still do it...
Old Oct 13, 2003 | 05:55 PM
My car is an auto, and I first noticed the issue after I changed the tranny oil and was running the car through the gears manually. When I held my car in first gear at low speeds it started jumping. But, I guess that's normal. Anyway, who spends their time cruising in first gear?
Note the wording:
Old Oct 13, 2003 | 06:01 PM
spirilis's Avatar
Stop'n'go drivers...
oh, like me!
Old Oct 13, 2003 | 06:29 PM
That's to bad. Your missing out on what your car does best. GO FAST!
oh, like me!
Old Oct 14, 2003 | 03:06 AM
GreekMaxima's Avatar
on my previous 2k2 maxima (auto) i had this problem... first to second gear JUMPED about 2000 rpm's or more sometimes... after couple months
did something BUT when i was on the light... "for example.. full stop" lets say i did 100 miles or more and i have to stop on the light... my car JUMPED to the first gear like crazy or no reverse...
Old Oct 14, 2003 | 03:48 AM
spirilis's Avatar
Hehehe, I got plenty of that this past weekend at the DC-area BBQ/meetup...
Old Oct 14, 2003 | 03:49 AM
you greek?
Old Oct 14, 2003 | 03:51 AM
spirilis's Avatar
That sounds more like a transmission problem to me...
Old Oct 14, 2003 | 03:53 AM
spirilis's Avatar
you greek?
no, why?
Yeap, i know... but no more!! I got 2k3 maxima!!
Old Oct 14, 2003 | 03:55 AM
no, why?
from "spirilis" thats why...
Old Oct 14, 2003 | 11:45 AM
IceY2K1's Avatar
That doesn't help for a consistent launch or jumping the tree at the track.
Oh well, it's not a race or track car anyways.
Note the wording:
Old Oct 14, 2003 | 11:56 AM
spirilis's Avatar
Makes me wonder if the Fuel Cut TSB pertains to this...
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
