2002 Acura TL-S
Old Feb 18, 2001 | 08:02 AM
Maximam's Avatar
I hope Nissan does in fact make the SE-R. With the 2002 TL-S kicking out 260hp, Nissan will have to step up. I think if the Maxima does use the 3.5 it will be more powerful than the Acura from the gain in torque. TL-S has I think 232ftlbs, I sure hope the 3.5 Max will have more torque. What does everyone think of the TL-S, I think it is a great car but would never turn on Nissan.
Mark
Old Feb 18, 2001 | 12:30 PM
nisMAXse's Avatar
Mark
Hmmm...I didn't know Acura was going to churn out a 260hp TL-S. Where can you find pics/info on it? I'm guessing it's the same engine as what's found in the current CL Type-S...??
Old Feb 18, 2001 | 12:32 PM
UMD_MaxSE's Avatar
Got Bent?
The TL-S is basically the same as a CL-S, except it has 4 doors.
Old Feb 18, 2001 | 03:54 PM
Maximam's Avatar
Mark
Check out this site:http://www.acura-tl.com/2002_TL-S.htm
Mark
Old Feb 18, 2001 | 04:02 PM
MichaelAE's Avatar
It still is yet to be known how this thing will perform. I've never driven the Honda sportshift. Any takers? The 4-speed auto is poor in my opinion. This car is just a pumped up 6th gen Accord. I think the CL/TL are still on that platform, right? I have a 6th gen Accord Coupe with the 3.0L...and it doesn't touch the Nissan 3.0L.
The Maxima is still meaner looking and lighter, so Nissan might not have to do anything to keep in the game...but if they do put the 3.5L in the Max...that Acura won't stand a chance. I question whether it will stand a chance against the current 3.0.
Old Feb 18, 2001 | 04:58 PM
miKALsof's Avatar
TL-S
2002 TL Type S vs. 2001 TL:
-64mm larger throttle valve
-lower air filter & duct flow resistant
-50% increased air flow
-dual-stage intake manifold w/ integral velocity stacks
-butterfly valve separates the front and rear cylinder banks at low speeds to take advantage of resonance charging
-intake valves of a high-flow variant w/ extra lip
-higher cylinder pressures = thin-wall spin-cast cylinder liners
-10.5:1 compression ratio
-larger exhaust pipe
-dual high-flow mufflers
-low-restriction catalytic converter
-6900 rpm redline
-increased second-gear clutch-holding ability
-modified torque converter
-higer-rate springs
-firmer shock valving
-bigger anti-roll bars
-215/50VR-17s
-17" wheels
-new grille
-new headlights
-new hood
-new bumpers
-perforated leather
-metallic instruments
-leather steering wheel
-torque sensitive power steering
-$3500 more
0-60- 6.9 seconds
1/4 mile- 15.1 @ 94
Top speed- 145 mph
Old Feb 18, 2001 | 06:12 PM
costcowholesale's Avatar
maxima will need the .5 cc displacment and a new automatic tanny to compete with the TL's 260hp, 5 speed automatic
Old Feb 18, 2001 | 06:17 PM
UMD_MaxSE's Avatar
Got Bent?
you mean .5 Liter (500 cc) right?
Old Feb 18, 2001 | 06:19 PM
oops yeah I mean 500cc or .5 liter
Old Feb 18, 2001 | 10:51 PM
Maxx-s-ter's Avatar
It's a 5sp auto
The TL has the 3.2L
Auto vs. Auto... the TL-S will smoke the max... TL-S vs. 5sp Max. pretty close.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Marc2theMax
Sep 28, 2015 08:13 AM
