Whats wrong with my brakes?!
Old Oct 22, 2003 | 12:18 PM
sypher's Avatar
When the brakes are cold, there is no problem. After using them a little, they start to have a grinding feel (and sound) to them. I can actually feel it on the floorboard of the car.. They also seem to get more sensitive (takes less pressure to stop) after they are warm. if i apply pressure to the brakes at high speed, the steering wheel shakes like crazy. I dont get much squeaking from them, but i have heard them squeak a little. do i just need new pads or is it a bigger problem? its a 2000 GLE with 45000 miles. thanks
Old Oct 22, 2003 | 12:25 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
a shaking steering wheel tends to point to warped rotors which is a know issue on 00/01. mine were warped at 9k. nissan has a tsb on warping rotors but you are out of the 36k/3yr warranty for tsbs. you can look at having the rotors turned which is a band aid fix or replacing the rotors. obviously have the pads looked at to see if the rotors caused any damage to them.
Old Oct 22, 2003 | 12:35 PM
Igor911's Avatar
Yep, they are warped. If your under 36k, take it to Nissan
Old Oct 22, 2003 | 12:42 PM
SoonerFan's Avatar
Cletus
he already said "with 45000 miles"
Old Oct 22, 2003 | 12:46 PM
Igor911's Avatar
Didn't see. Then buy aftermarket rotors
Old Oct 22, 2003 | 12:47 PM
sypher's Avatar
whats the horrible grinding noise and feel?
Old Oct 22, 2003 | 12:49 PM
sloppymax's Avatar
probably metal on metal contact with the caliper and rotor. the pads are probably close to non-existence.
SoonerFan's Avatar
Cletus
your rotors are warped and grinding against your pads
Old Oct 22, 2003 | 01:47 PM
pashe's Avatar
I have the same problem!!!!. Ever since I installed new pads, I've had issues with my brakes.
I'm considering slotted rotors. I haven't heard of any aweful drama with those.
Old Oct 22, 2003 | 03:18 PM
GreekMaxima's Avatar
vibrate like crazy... the dealer wants $140 for just clean them... fu*k that... i'll get aftermarket rotors with $30-$40 more
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
