Where is the PCV valve?
Old Oct 22, 2003 | 08:02 PM
dvenki's Avatar
Can anyone tell me exactly where the PCV valve is?
I want to replace it and wanted to be sure I unplugging the right thing.
Old Oct 22, 2003 | 08:41 PM
spirilis's Avatar
at least on 2K, it's in the valve cover, near the throttle body, on the rear (facing the firewall) side of the V... it's sitting under the intake plenum if I recall correctly.
Old Oct 23, 2003 | 09:46 PM
dvenki's Avatar
spirilis : I am lost looking for it. I looked at the bottom of the intake manifold and it looks to be well disguised somewhere.
Can you be a more specfic to its location?
Thx
Old Oct 24, 2003 | 03:50 AM
spirilis's Avatar
Exactly what year car do you have?
Old Oct 24, 2003 | 08:14 AM
dvenki's Avatar
It is a 2000 Maxima
Old Oct 24, 2003 | 08:27 AM
spirilis's Avatar
See if this picture helps:
http://atlantis.phantasus.net/~spiri...VQ-PCVhose.jpg
Keep in mind, there's only 1 PCV valve in our engine... crankcase gases from the front-side bank get vented to the rear-side through a hose towards the passenger side I believe... (the PCV breather hose also goes into the front-side bank, so circulation occurs through the rear of the front-side bank, to the front of the front-side bank, then crosses over to the front of the rear-side bank, then towards the rear of the rear-side bank where the PCV valve is located)
Old Oct 24, 2003 | 09:51 AM
nellynel's Avatar
Is the pcv valve easy to change? I am almost affraid to touch anything fearing a ses light might come on.
Old Oct 24, 2003 | 10:59 AM
spirilis's Avatar
Yeah, pull that hose off the metal bracket holding it, then gently pull the PCV valve out of the valve cover (it's not bolted/screwed in), pull off the hose clamp, put the new PCV valve in, gently push it back in...
Get an OEM PCV valve; I've tried the Autozone PCV valve, it's a ***** to install (doesn't go in easy like the OEM), and I'm not sure if it even works correctly... (smell oil fumes once in a while, so I bought an OEM PCV valve which I'll need to install tomorrow when I have the time)
Old Oct 24, 2003 | 11:37 AM
dvenki's Avatar
I got the Deutsch P169 valve from Autozone ... Is this fine / go to the dealer and get the OEM valve?
Thx anyway for helping us out .. looks like my dealer hasn't changed it for my 30000 miles servicing ... but did take $500 from me (this value costs a paltry $4).
I shall try the OEM filter in place of this!!!
Old Oct 24, 2003 | 12:18 PM
spirilis's Avatar
That's the exact one I used, take it back to Autozone and get a Nissan OEM PCV valve. Should fit MUCH better. My OEM one cost $10, and had to be special ordered (maybe because they're a fairly smaller dealership and didn't have much room for parts stocking...?)
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
