Recieved Cattman Coilovers today...*pics*.....
some pics for those that wanted to see the impressive design of these coilovers. so clean, so firm....too bad it got TOO cold for to finish installing them. i will see if i can do them sometime next week. after taking apart my front suspension, i realize now how EASY suspension is.
some pics for your pleasure
Originally Posted by 2k2whitemaxi
what is the advanage of coilovers verse lowering springs???
-J
-J
but then coilovers can get separated into 2 categories. basic coilovers are just the spring and the thread. "better" coilovers come with a strut/spring combination, aka coilover system. since they are designed for coilovers only, they are also designed to handle the extreme pressure and spring rate due to the possibility of someone setting the coilovers to the lowest possible height. these cattman coilovers have the same spring rate, no matter what height. that's called linear spring rate, vs. variable (in other words, based on your height, you can have dif. spring rates simply on how much time the strut has to react)
price is always the biggest issue. basic coilovers (first one i mentioned) can be had for about 300-350, used going for much less. and again, that is JUST the spring. coilover systems include both strut and spring, plus the advantage of offering a superior spring rate. but then that price jumps to 1000+, very rarely seeing $1000.
peoples choices are mainly decided based on their budget. want to spend 350 or 1200. you pick.
Originally Posted by Gooey
i have a quesiton....it sounds stupid and from pictures im thinkin the answer is NO..but if you have coilovers do you need struts? no rite?
Read the 3rd post above this one (PoLo's).
Basically, you need four struts to be installed in your car, when running, at all times. The Cattman coil-over system includes struts, if that's what you're asking.
~limsandy
just installed the coilovers....new thread discussing the review.....
Cattman Coilovers Installed....Review.....thumbs up!!!!
KabirUTA13
19
Oct 17, 2015 02:15 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
