Foglights dont work now??????
Old Oct 29, 2003 | 04:44 AM
SeOh2mAx's Avatar
Cant..leave..the..ORG!!
Ok I had the foglight rewire on my 2k2 done and it worked fine. well when I switched out lights (for a set with the orange already cleared from) then I had to undo the wire tap. well it sat for a couple days before I got a chance to hook it back up and now the stupid fog lights dont work at all???? All the other lights work fine I pulled everything apart and checked all the connections and made sure they were tight.
Does anyone have any clue what it could be? I also checked the the fuses and those are all good to. So any help would be appreciated.
Billy
Old Oct 29, 2003 | 08:07 AM
htt79's Avatar
what probably happened is that when you installed them you probably touched the bulb. and those lights are super sensitive and the oils from your skin will mess those things up real quick. that's what they said happened to mine. so next time you install them dont touch the bulbs.
Old Oct 29, 2003 | 10:33 AM
SeOh2mAx's Avatar
I've never touched the Fog light bulbs...they are the only bulbs not working...the only thing I have come anywhere near is the wiring which is all tight and well connected.
tomorrow when I get the chance I will probably be totally undoing all the wires and hooking the fogs backup properly and try to go from there!!
Any other ideas?????
Old Oct 29, 2003 | 11:43 AM
NYC TAR's Avatar
By the way is your Hi -Bean on. That can cause the fog to not turn on. This might be it, this has happen to me.
Old Oct 29, 2003 | 12:18 PM
slizan99's Avatar
with the foglight rewire the foglights should stay on even with highbeams.
Old Oct 29, 2003 | 12:53 PM
Jopa416's Avatar
Clarification
I re-wired mine, and the fogs work fine without the headlights, but they still turn off when the highbeams are on.
Interestingly, when I re-wire a Probe GT I used to have the fogs would stay on with the high-beams.
Why don't manufacturers just make them this way?
Old Oct 29, 2003 | 12:54 PM
NYC TAR's Avatar
Not on the 5th gen. I think there is law that you can have only 4 llght on at a time. unless, he had it rewire to turn on with the hi. I know the bmw can can do this.
Old Oct 29, 2003 | 03:05 PM
woosh's Avatar
It's possible when you left it hanging a couple of days the wire shorted against the body of the car.
Check the fuses. If they look ok, I'd suggest reverting back to the stock connection configuration. If that doesn't work something is really F'ed and will require a meter to diagnose or a led and a 1K ohm or greater resistor.
say when
SHIFT_woosh
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
