2K2/2K3's with teins, need feedback.
Old Oct 31, 2003 | 12:00 PM
2k2MerlotSE's Avatar
JUVIN's ride
What's up guys.
After searching and reading, it seems that a camber kit or bolts will help in the tire wear. But there are a lot of differences in opinion. Some say you need it some say you don't.
My question is how are your tires wearing? Are they even? Would you recommend just getting the bolts or kit?
How many miles do you have on your current suspension setup?
Thanks in advance.
Old Oct 31, 2003 | 12:16 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Not needed with Teins and stock wheels...dunno about aftermarket. I still have plenty of adjustment left as well...
Old Oct 31, 2003 | 12:19 PM
JUVIN's ride
So the saying " If you drop your car mor that 2 inches you will need camber plates/bolts" does not apply to teins.
Doesn't the front teins drop around 2.2?
Old Oct 31, 2003 | 12:24 PM
OT n00bs FTMFCSL
Yes and yes...
I have no problems at all with my Maxima or any suspension components/wheels/tires. They are still within the stock specs as of this moment...
LithiuMax
I have Teins and I didn't use a camber kit, because I was told not to by all of the various responses I read using the search feature...
Old Oct 31, 2003 | 12:28 PM
JUVIN's ride
Yes and yes...
how many miles did you put on your set up.
Old Oct 31, 2003 | 12:41 PM
MaxSE03's Avatar
Teins, no camber kit, 5000 miles, and no tire wear. I just rotated them a few weeks ago and they still look perfect.
Old Oct 31, 2003 | 12:42 PM
OT n00bs FTMFCSL
15000 so far...yes, I drive the pi$$ out of my car. It's not even a year old and it already is just short of 28K miles...
Old Oct 31, 2003 | 12:51 PM
ukeyman's Avatar
No wear problems either. Plenty of adjustment left according to the guy that did mine. Had them 3 months, 4,000 miles.
skandalouz's Avatar
same here.. got teins for about 15000... tires seem fine...
shiet quicksilver.. i got about 21000 in ten months also.... everything in georgia is so far away from each other.....
Old Oct 31, 2003 | 12:57 PM
OT n00bs FTMFCSL
We've probably driven past each other 100 times this year My two year old Dakota (4.7L V8) has 48K miles on it...I just like to drive!
Old Oct 31, 2003 | 01:09 PM
Triple8Sol's Avatar
I miss the .org!
I did not cut the bumpstops and did not install camber bolts/plates. So far so good, we'll see...
Old Oct 31, 2003 | 07:47 PM
maximadave's Avatar
detailerdaveb@gmail.com
5K miles with Teins. No abnormal tire wear at all and just had my wheels rebalanced.
Old Nov 1, 2003 | 11:59 AM
jaco's Avatar
I did alignment afer about a week I had the teins on. Looking at the print out, the before numbers were pretty much within factroy specs.
But if you want perfect numbers all around, then get camber bolts.
Old Nov 1, 2003 | 02:12 PM
trey
i got teins, no camber kit, no alighnment no tire wear.
MannyMonroe
Sep 25, 2015 12:38 PM
Ben2003GLE
Sep 24, 2015 04:25 PM
adamgalazka
Sep 8, 2015 01:27 PM
Wustylez
Jan 22, 2001 03:20 PM
