Gauge pod without SC or Turbo: too ricey?
Originally Posted by LithiuMax
Where else can I put gauges that I want? It's not like I am putting Boost gauges in without actually having boost; to the contrary, I want oil pressure/temp and voltmeter gauges. Any other place I can put them without having to do much custom work?
Try putting them in the ashtray/coin collector area. Mold/build a custom fiberglass gauge holder (panel contoured to match existing area) and mount them there. Wiring should be rather simple to get in there as well.
That would be tight; however, "molding fiberglass" = much custom work, at least for me.
**** man, that's like 2 days worth of work tops...
Unless you really suck at sanding and painting
Originally Posted by look2me40
I have 6 gauges and no turbo or sc.
Seriously, Lithu, getting gauges for no good reason is pretty ricey. If you are running 10,000 watts, maybe a voltmeter would be necessary. But oil pressure and exhaust temp? Come on.....
Basically, if you have to actually brainstorm on what gauges you think you need, you really should not get them. Get some damn wheels......
its your car, do what looks gangsta to you!
Originally Posted by nismotech
Oil Pressure, Oil temp, Air/fuel ratio ( My choice, for application w/o FI)
Why do you care if its rice or not, if it looks good to you then go ahead and do it. After all its your car~
Originally Posted by asu174
You have nitrous. You need the gauges even more than a boosted car.
re:
I'm thinking of getting the Custommaxima triple gauge pod in black from the GD in the GD forum. I don't have a Turbo or a SC, but I was thinking of putting a Voltmeter, Oil gauge and one other gauge in the pod. Would this be too ricey? I think it would be pretty cool, but aside from the rice factor, what other gauges can I put in there that will be functional other than Oil and a Voltmeter? Thanks!
Your point? You have NAWWWZZ. You need them.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
