Stillen header dyno numbers!!
Ok here's the lowdown on my 3 runs from yesterday. The first 2 runs were pretty much the same with both yeilding 221hp, 225tq, the 3rd run yeilded 227hp, 231tq. I'm not pleased with the first 2 runs, but the 3rd is a little better. Overall I'm happy, but at the same time I'm dissapointed. The numbers were good, but they don't show the gains that I was expecting. Especially, if you think about how each product gives there claim of dyno numbers. It doesn't add up. Even if you go off the lowest numbers from each of the company's claims I'm still around 12 hp off. Which obvouisly would come from the headers. Given that a stock Maxima dyno's somewhere around 200-205whp this means that the claims from each companies is almost dead on except for the headers. Going from 200-205whp stock, you add 5hp for the Stillen rear section, 5hp for the Udp, and 10 for the Injen CAI. This means the headers yeilded between 2-7hp....where's the other 12-17hp. Anyway if your thinking about headers, I would advise you to reconsider. Until me, Will and Studman find out what is causing the loss. I would reccomend staying away from wasting $900. By the way you can also see the graphs by going to my homepage and clicking on page 7.
Originally Posted by 92 SE-R 02 SE
thanks for the update. Between you, will and studman, i for one will not be getting $tillen headers. Lots of us appreciate all the time, $$ spent on dynos! thanks!
Unless it's some type of new charity thing I didn't know about...
G
Originally Posted by 02MaXiMa_GLE
Um, I think people actually get their car dynoed for there own benefit and not for us, right?...
G
G
G
G
If we dynoed our cars for just our benefit, we woulnd't post the info here
. This is called consumer awareness, and sometimes it takes the proverbial sacrifice of others to get the correct information out about certain products available to the consumer...The sacrifice for the headers is time and money, so learn this lesson well. If we get several more dynos of the headers (on a Dynojet, I must add...) and they continue to show either a loss OR significantly lower gains that what are advertised by Stillen, then there should be some kind of compensation for the ones that purchased the headers. Also, this would warn potential consumers of the alleged false advertisement claims of Stillen about the headers...
Catch my drift?
http://images.cardomain.com/member_i...50_99_full.jpg
http://images.cardomain.com/member_i...0_101_full.jpg
Man, I'm truly sorry that your gains were not what they should be. This is just a continuation in the disturbing trend of aftermarket companies making claims that don't add up in the real world...
Catch my drift?
Catch my drift?
G
man that is extremely beat...i was ready to go and order my headers until i read about wills ordeal. this is honestly really depressing...u should definately contact stillen (not knowing much good that will do) and just prove ur point...or flip out (which i would do) and maybe theyll hook u up with something...how can a major company like stillen screw up this bad....that ****es me off....o well...hopefully some company will produce headers better headers eventually....i was thinking about just getting a y pipe for now but i want my car to b street legal and popping that **** off would be such a pain in the ***....just venting peace
I highly doubt the UDP gave you 5hp. I would be more likely to believe 2-3 max. Also the 10hp on the Injen is tough for me to believe to. I would be more confident in say 7hp. Of course those claimed numbers could be peak gain from anywhere on the rpm range so they would not necessarily "stack". I beleive your information is unreliable as to solid information on how the stillen headers perform. The only solid information would be how an 02 or 03 auto would perform with that same set up. You cannot truely claim to know the hp gain from the headers becuase you did not do a "before" dyno.
Using my numbers:
biggest possible estimated gain: 227-200-2-7= 18hp
smallest possible estimated gain: 221-205-3-7= 6hp
Using your numbers:
BPEG: 227-200-5-10= 12hp
SPEG: 221-205-5-10= 1hp
As you can see the variance is huge, but that is all you can reliably claim. I would be more likely to beleive the numbers I stated which would then indicate the headers giving you an estimated 12hp, which is lower than what Stillen claims but close. And again your peak hp might not be where Stillin claims the PEAK GAIN to be. But again I would like to say that this is all estimation becuase we do not have any reliable "before" data.
Dont pass judgement on the Stillen Headers yet becuase I feel we do not have ANY reliable data on them yet. Whe have had dynos from 2 cars that the owners stated "werent running right", a couple of positive butt dynos, and a dyno with nothing to compare it to. Unless I missed something I would have to definitively say NO RELIABLE data is available yet. Currently I beleive you are all jumping to conclusions.
Using my numbers:
Using your numbers:
Using my numbers:
Using your numbers:
Using my numbers:
Using your numbers:
Do you have the headers? If so, have you done baseline (before headers) and after headers dynos? If not, then you have nothing to add but conjecture and speculations. We're the one's spending our hard earned money buying these products and paying for the dyno runs. We're the ones going to swap the headers to another car in a perfect state of tune and test them on the dyno again. Until you actually have something useful to contribute, please post no further.
Everyone who has dynoed has had problems (HP/TQ lost) or significantly lower than advertised HP and TQ gains. As one of the extreme technically minded folks here, I'd say that sthis hows a disturbing trend. Will's car has a hesitation glitch, yes, but the glitch isn't where he's having the huge loss of power (over 4K RPM). The loss of power seems to appear right when or slightly after the secondaries open up. This could be due to ECU overcompensation, in which case Stillen is lying out their a$$ about the gains they got. Supposedly they have "over 100 dynos" with gains on a stock exhaust (other than their headers) Maxima. Their 19 HP gain (over a stock 205 average) would put people at 224 WHP (with a stock exhaust setup) on average. But do recall the fact that Will's '02 SE made 228 WHP & 236 WTQ with the HKS rear, 2.5" B pipe, RT high flow catalytic convertor, and someone's Y pipe (whether it's Warpspeed's or Cattman's, I don't know...I'll have to ask). Look at 1BADMAX's very last dyno. That's the one that closest to where it should be. But in my eyes (and according to Stillen's dyno claims), he's anywhere from 10-15 WHP short of where he should be. TQ is also pi$$ poor across the board (in my not so humble opinion). Don't let you like of a certain name brand blind you into buying something that so far has been proven not to work...
Hot Shots look similar right? Only big diff is the 02 sensors ore moved downstream of the main cat.
Removing the precats and putting the 02's back in before the main cat would cause them to read more 02 than they are used to (at least I think so because it would cause less of the o2 to become co).
And it is going way rich which would be the case if this theory has merit.
Hate to see you guys do all this swapping, that is a hell of a lot of work. To get some threaded ports welded behind the cat could'nt cost that much and it would be easier than the swapping. Not too hard to plug up later.
Stillens black box is a fit in this scenario as well (o2 upstream information not being manipulated to mimick downstream info).
If somebody has suggested this before, i missed it and am sorry.
Stillens black box is a fit in this scenario as well.
I somebody has suggested this before, i missed it and am sorry.
We might try unplugging the stupid black box...just to see what it does. And switching headers to another car actually won't be that bad (we'll have a lift and all the tools/help we need). I can guarantee you that none of us are going to buy another set just to test
will
all of that is correct except i had a Stock y-pipe
hehehe! will
ok now reset the ecu with witohut the black box being attached. I noticed when i was attached, when i reset it the ecu it didnt reset as it doesuyssaully by blinking 10 time fast the repeating this pattern. With the black box i reset it and its blink maybe 10 times then it does not repeat the pattern and the light stays on until i restart my car.
Well 1BADMAX's plots don't have that strange dip like Will's does, but the AF goes rich at 4.8k and that when the TQ starts dropping. That's also where the HP flattens out some.
My car had a Warpspeed B w/res and a flowmaster 50 series (I also added another 12" res to the B), a Firm Fab. mid pipe with a $tillen Pop for the intake & UDP, everything else is stock, when I dyno'd with Will last month. My numbers were HP 212.xx & TQ 231.xx.
The shop overlayed Will & my plots for us to look at and up untill his dip they were like carbon copies...
I have since put the Frank mid back in which uses the stock MAF tube with the screen. I have not been back to test again yet. I felt my HP numbers were a bit low for the TQ I am pulling.
Will, why don't you go get some new plus today and come over to my house tonight or tomorrow and lets put'em in. With 60K as hard as you've pushed it I bet there toast. They need to be done anyway so lets see if that helps.
For what it's worth, here's another thread about an Altima make 251 whp after the Hotshot header install.
http://www.nissantalk.com/forum/show...hreadid=130358
Thanks for depressing me even more...
http://images.cardomain.com/member_i...33_85_full.jpg
Not to nit pick, but STD vs. SAE correction and a mobile dyno?
The pessimist side of me is doubting those numbers would be the norm. Any stock dynos or somewhat stock dynos from that day to use for comparison?
You guys are going to uninstall Wills headers and then install/uninstall on Adams' car?
If so,
and PLEASE get Adams' car dynoed BEFORE, then after to nip this in the butt once and for all.
I'll give $25 to whoever is paying, if that's the plan.
If so,
and PLEASE get Adams' car dynoed BEFORE, then after to nip this in the butt once and for all.I'll give $25 to whoever is paying, if that's the plan.
Adam, where do you live? PM me you address and # so I can get you into my phone. I told will the same thing about changing the plugs (just come over and get it done)...
If so,
If so,
I've since gone from a Firm Fab/$tillen Pop back to the Frank/$tillen, no other changes. I may dyno again donno.
We are going to change out Will's plugs 1st. and I hope he gets his ECU reflashed by the dealer. He's talked about a TS reflash but I think he's short on cash. Will-->
<--$tillenIf after the new plugs there's still no improvement I think we'll do the swap, I'm hoping to get use of the shop Sat. if not early next week if we all can get together...
If so,
If so,
As for the ALTIs #...seems high, the one guy has all the same mods and put down about 10-15 LESS HP...so, i think the mobile dyno is off. Then again, i never know what the hell im talkin about!
I'll give up $25 as well. hit me up with a PM to mail a check too. You guys are great for going thru all this BS!!!
The Alti numbers do seem high but even if they're 10-15 hp off the put the range at 236-241 which is probably the results we should be getting with a 6 speed.
Due to the inconsistencies of the dynos(and differences of dyno systems used) the only
hard evidence that these headers make good power is that Juice ran the quarter faster than he
ever has- thats evidence enough that the product
works - It will be hard to tell if the gains are what Stillen claims-
I would like to know if an org member has improved their 1/4 times w/ the Cattman Y- If so by how much?
This would conclude whether spending a $1000
for headers is worth it, Or spending $350 for the Y
would be "smarter" (same performance increase/less noise/less $$$$)
Regardless if Alty's are pumping out 250+ hp from HS headers, there is no excuse why Stillen's are not
yielding similar power increase(product flaw)
Good luck guys!
Good luck guys!
I am starting to think that Black box may be affecting everyones power. I never installed it when I ran my best times and have not installed it since. It has been 5 weeks with no check engine light. To all of you who dynoed like crap..DO YOU HAVE THE BLACK BOX INSTALLED?
Ok...
IceY2K1 = $25
92 SE-R 02 SE = $25
03BlkSETE = $??
Rest of you guys NEED to help these guys out. This is the ONLY way we'll get to the bottom of this and the rest of you will either A)Have another mod to buy or B)Save $900 and go buy a ypipe or TS ECU or both.
Time to cough it up IS NOW!!!!! No reason Will, Quicksilver, and maximaman777 should pay for all this themselves when SO MANY of you are supposedly interested. Bandwagoneers NEED to jump on board or I say let them keep whatever they find out to THEMSELVES.
IceY2K1 = $25
92 SE-R 02 SE = $25
03BlkSETE = $??
disconnect the dam module it pulls harder and no lgiht comes on. Stillen is full of Sh$$. Also i can reset my ecu and it works now without it on. Its easy just disconnect the ground. also I will be dynoing tomarrow.
DynoJet glen?
Good luck guys!
Good luck guys!
1BADMAX, WILLSE, and studman all used the same exact type dyno (with WILLSE, 1BADMAX, and maximaman777 using the same exact dyno in the same exact location). I'd say that's pretty damn scientific and lays waste to your claims of inconsistencies...
Ok...
IceY2K1 = $25
92 SE-R 02 SE = $25
03BlkSETE = $??
IceY2K1 = $25
92 SE-R 02 SE = $25
03BlkSETE = $??
.....are u going to call stillen?
oh, god-
