Just installed a y-pipe and now i've got a vibration... HELP!
Old Nov 15, 2003 | 09:42 AM
kcowden's Avatar
Just installed a warpspeed y-pipe and it went on ok. At idle there it's fine but once I step on the gas there is a vibration around the auto shifter. Can anyone help me figure out what to do. Thanks in advance for any thoughts.
Old Nov 27, 2003 | 09:52 AM
white m3 guy's Avatar
there is a black bar on the midpipe
Old Nov 27, 2003 | 09:53 AM
you have to remove that i had the exact same problem with my ypipe, the pipe hangs a lil bit lower which caused the midpipe to hit the black bar
Old Nov 27, 2003 | 11:57 AM
3.0HO
It's actually a cross beam that has 8 bolts I believe. You can also try using washers on each bolt as spacers. It depends how close your pipe is under WOT since the engine torques in the engine bay and moves the whole damn exhaust.
Old Nov 27, 2003 | 04:50 PM
indigomax's Avatar
my car did that...but after some days the vib gone
Old Nov 27, 2003 | 05:33 PM
Triple8Sol's Avatar
I miss the .org!
I also had this problem. You have to remove that black brace, and you may also have to adjust the bracket that goes to the rubber hanger..
Old Nov 28, 2003 | 09:43 AM
kcowden's Avatar
It was both of the supprot brackets that were banging, I had to rearrange the POS hanger that came with the y-pipe ( not sure how long that will last) I used washers to add some clearance on the 8 bolt front brace ( it looks pretty beefy and I thought I should try to keep it on) Removed the rear support brace, for now (will work on that later) I'm going to make my own support hanger later. All in all I'm pleased with the power, very smooth and responsive. Thanks for all the help guys, were lucky to have this type of forum to help each other out in times of need
Old Nov 28, 2003 | 01:21 PM
jerome johnson's Avatar
I had same problem even after lowering cross member 1/2 inch. Ended up selling the pos because I lost midrange h.p. with y pipe.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
