Condensation in rear clears
I believe I found the source of the problem with condensation forming in the rear clears. Mine left one only gives me problems.
I pulled it off today, and as I moved it around, upside-down, etc, I noticed there was more than condensation. Water had collected in there and it was sloshing around.
I moved it around on all ends until I felt some water leak out. It was where the housing and the lens comes together around the BIG end.
I am trying to dry it out. I'm going to use the sealant I purchased for my front clear project, which isn't going to happen since I ordered some from AutoDynamic.
I am thinking about running a small amount around the entire lense where the housing meets the lense. It should not hurt anything since this part is not visible from the exterior of the car.
I chipped the lense when I took it off the car.
Originally posted by Y2KevSE
Just make sure you don't force it out too hard or else... *CRACK* I can take the markers out in about 2 seconds, so if anyone is missing their markers...
The mission: Steal 50 marker lenses.
I shook the water out, but condensation, small traces, still formed. It is almost like a film.
I tried baking it in the oven at low temperature like a baked potato, in aluminum foil. That got rid of some of it. It still comes back.
I baked it extra long and most went away. I sealed it where it was leaky and re-installed it. Maybe one day the moisture will just evaporate.
doctorpullit
09-10-2015 06:33 PM
ef9
09-05-2015 11:18 PM
