Do I need to service my brakes ??? Have a slight "pulsing" when trying to stop
Old Nov 22, 2003 | 08:59 AM
Ferbs02SMMax's Avatar
Hey all. The Max has 30K miles on it. Admittedly, I drive it hard and brake hard. I hear no grinding noise when I hit the brakes, and the braking distance is good, but if I slow down from lets say 20 mph, I feel a pulsing sensation on the pedal, and when the car slows to 5 mph, I feel the front end sort of "rocking" back and forth (almost indistinguishable) until it comes to a stop. Maybe thats something to do with the alignment, but I doubt it. The car tracks true.
What mileage have you guys had the brake pads done ? I dont want to put $150+ in anybodys pocket just yet, but I dont want to damage the rotors either.
Old Nov 22, 2003 | 09:03 AM
SoonerFan's Avatar
Cletus
almost seems to me like you may have low brake fluid. or there are air pockets. i would say bleed them but if you have never worked on them there should be no air. maybe fluid.
Old Nov 22, 2003 | 04:25 PM
stinger73's Avatar
[QUOTE=Ferbs02SMMax], but if I slow down from lets say 20 mph, I feel a pulsing sensation on the pedal, and when the car slows to 5 mph, I feel the front end sort of "rocking" back and forth (almost indistinguishable) until it comes to a stop. QUOTE]
________________________________________
The pulsing feeling usually is associated with Warped Rotors. If you are braking hard, you generate a lot of heat, and if you do this when it too cold outside the rotor tends to cool quick causing it to possibly warp a bit.
Have the rotors checked, that is what I would recommend.
Old Nov 22, 2003 | 04:26 PM
DanL's Avatar
Your rotors are warped. You can easily take them off yourself (will
take about 5 minutes per side -- all you need is a 14mm wrench to
remove the two caliper bolts). Getting them both turned will cost around
$20-$30. Unfortunately, if you often brake hard, they'll probably
warp again. You might want to think about decent aftermarket
rotors/pads. Also, make sure your wheel lugs are torqued properly.
I always torque mine in stages to 80 ft lbs
Old Nov 22, 2003 | 05:22 PM
irish44j's Avatar
retired moderator
I too have noticed this...what are the best options for aftermarket rotors that don't cost a fortune? And would you have to get new calipers too? Though I don't do alot of hard braking generally.....that sucks that stock rotors would be this poor in quality, but seems its a problem that pops up on maximas alot...
Old Nov 22, 2003 | 06:46 PM
Zero Deuce SE's Avatar
I don't think the rotors are of poor quality. I have owned 3 Maxima SE's through the years. The braking system has always been good for me. Even when I did aggressive braking. Sometimes rotors get warped by improper torquing and/or using an impact gun to tighten them. Of course you can always get better brakes if you want to spend the $$$$$.
Old Nov 22, 2003 | 06:53 PM
irish44j's Avatar
retired moderator
Interesting...wonder if this could have been caused when I got new tires and they used the gun on the lugs....
Old Nov 22, 2003 | 07:02 PM
It is very possible. They try to tell you that they are not applying that much torque with their impact guns. They are fullofsh*t. I work with impacts at my job and they can have up to 400+ foot pounds when tightening fasteners. I always insist on hand torquing when someone has to remove my wheels for any service. I actually check them myself before I leave the place. I carry a torgue wrench in my trunk.
Old Nov 22, 2003 | 07:10 PM
irish44j's Avatar
retired moderator
thanx for the info...will have to dig up my torque wrench and check them....
Old Nov 22, 2003 | 07:14 PM
You're welcome. If they are already warped, it may be too late to do anything by retorquing them. I had a problem like that with a Honda Civic that I bought used. I had to replace the warped rotors to stop my pulsations. The lug nuts were on so tight that I had to use a long 1/2" drive breaker bar to loosen them.
Old Nov 22, 2003 | 09:12 PM
hey, you guys aint half bad, thanks for the headsup. always able to provide a solution. i will have the dealer look at it and let me know a price, and then have a friend who works at a dealer do it before it gets real cold outside.
RWCreative
Sep 21, 2015 11:01 AM
Maxxx10
Sep 13, 2015 03:16 PM
minsbang
Sep 11, 2015 08:48 PM
bbsitum
Sep 11, 2015 04:55 PM
crazyespn
Sep 3, 2015 01:30 PM
