Need Help, SES light -little long
Old Nov 22, 2003 | 11:53 PM
KP ROX's Avatar
Yesterday, while driving on the highway, the SES light came on. Then when I got off the highway and into the city, the car would shake like it was about to die when I started to approach and then stop at a traffic light.
I went to a restaurant for a few hours. Afterwards I go home, the SES light is on, but the problem I had before is gone. Next day I go to autozone and have them pull the code, it shows 1320 which isn't in their system.
I go home, turn the car off for about three hours, unhook the negative terminal. Started the car up and began driving again. SES light wasn't on and the problem I'd experienced before still wasn't occuring.
Now today, I went out and ran some errands, no problems. Then tonight, I start driving and the SES light comes on again and I start having the same shaking when I'm slowing to approach and stop at a red light.
I don't understand it. I put on the Frankencar intake about a month and a half ago without any problems, no SES lights or anything. I checked the hoses attached to the intake, no tears, and checked the intake for any leaks, nothing.
Does anybody have an idea of what the problem could be? Could it be a fuel sensor or something, cuz i'm thinking the shaking is due to fuel not flowing smoothly through the engine. Any help woud be appreciated.
Old Nov 23, 2003 | 12:25 AM
jonbth's Avatar
This is from the service manual, P1320 ignition signal
On Board Diagnosis Logic
NFEC0288
Malfunction is detected when the ignition signal in the primary circuit
is not sent to ECM during engine cranking or running.
Possible Cause
NFEC0572
I Harness or connectors (The ignition primary circuit is open or
shorted.)
I Power transistor unit built into ignition coil
I Condenser
I Crankshaft position sensor (REF)
I Crankshaft position sensor (REF) circuit
Old Nov 23, 2003 | 01:40 AM
mad2kmax's Avatar
manual or auto?
Old Nov 23, 2003 | 07:33 AM
KP ROX's Avatar
Originally Posted by mad2kmax
manual or auto?
its a 2k auto
Old Nov 23, 2003 | 07:45 AM
KP ROX's Avatar
NFEC0288
Possible Cause
NFEC0572
shorted.)
I Condenser
jonbth, thanks for your response. I'm wondering if this is something I can fix or if I need to take it to the stealership.
Old Nov 23, 2003 | 08:18 AM
KP ROX's Avatar
NFEC0288
Possible Cause
NFEC0572
shorted.)
I Condenser
Also, wouldn't this be covered under the powertrain warranty?
Old Nov 25, 2003 | 12:06 PM
jonbth's Avatar
I think it would be hard to pin down without a diagnostic computer. The dealer might be the best option.
Old Nov 25, 2003 | 12:27 PM
spirilis's Avatar
NFEC0288
Possible Cause
NFEC0572
shorted.)
I Condenser
"Condenser"... this reminds me of something; Nissan Direct Ignition systems typically use a condenser (capacitor) somewhere in the circuit, anyone know where this is located on the VQ30DE and VQ35DE? I wonder if this could be the cause of any ignition system problems...? (maybe cause the coils to blow easily?)
I forget specifically why it's used... I think it might be used to ground out noise/excessive transient voltages in the primary circuit, but I'm not sure. I got that idea while looking at a schematic for the CA18DE (1988 Nissan Pulsar NX SE), which used an early version of NDIS.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
