Foglight Rewire Instructions??
Old Nov 24, 2003 | 11:34 AM
Mkang513's Avatar
The how-to in the FAQS don't work and the search is disabled. Anyone have a how-to? I just need to rewire them so they go on with my clearance lights.
Old Nov 24, 2003 | 11:47 AM
Igor911's Avatar
open the relay box under the hood, cut the blu/yellow wire under the fog relay, connect the end comming from the relay to the green wire on the parking light.
all done
Old Nov 24, 2003 | 11:54 AM
kcowden's Avatar
all done
I have the corners wired to blink with the turn signals.... any problem with rewiring the fogs??? Thanks!
Old Nov 24, 2003 | 11:55 AM
Igor911's Avatar
nope, those are 2 diff sources of power.
You are powering corners off of turn signal. He will power his fogs from parking light.
Old Nov 24, 2003 | 12:01 PM
kcowden's Avatar
I have an 03 SE, will the wire colors be the same?
Old Nov 24, 2003 | 12:14 PM
Igor911's Avatar
i think so
Old Nov 24, 2003 | 01:28 PM
ICULookN's Avatar
I just installed the clear brake led and re-wired my fogs yesterday, it was a b**ch to take off the fuse box. Once you take off the box it's easy.
Old Nov 24, 2003 | 01:39 PM
jesse's Avatar
VTEC This!
haha yeah that ****ed me off too
Old Nov 24, 2003 | 01:42 PM
Mick Max's Avatar
Wild at Hurt
Just a tiny point here. My 03 wire was (99% sure) blue silver. It could be that the 02 was blue yellow for all I know.
Old Nov 24, 2003 | 01:46 PM
ICULookN's Avatar
I would suggest you purchase a 10mm bolt and unscrew the 2 screws that holds it to the frame to make it easier.
Old Nov 24, 2003 | 01:51 PM
Igor911's Avatar
i forget its either blu/sil or blue/yel.
Old Nov 24, 2003 | 01:57 PM
ICULookN's Avatar
It's blue with silver dots.
Old Nov 24, 2003 | 03:57 PM
Mkang513's Avatar
all done
Cool. Thanks.
Old Nov 24, 2003 | 06:45 PM
gtbigup's Avatar
fog light rewire
Hey guys with the fog light rewire, do you still have the option to not turn it on or does it come on automatically with the parking lights?
Old Nov 25, 2003 | 07:43 AM
ICULookN's Avatar
You still have the option of turning it on independently of the parking lights.
Old Nov 25, 2003 | 08:05 AM
spirilis's Avatar
You still can't get them on with the high beams, though... upon initial inspection of the schematics I think it's possible, but would require removing the lighting/turn signal switch arm from the steering column, taking it apart and doing some internal rewiring... not sure how hard that'll be. This is so you can use the stock foglight switch to keep the foglights on with the highbeams on... if you don't want to go through all that trouble, you could install a new foglight switch instead... but it wouldn't be as nice
Old Nov 25, 2003 | 11:18 AM
scorpiao's Avatar
Is it the same procedure for 00? (As far as wire colors and location)
Old Nov 25, 2003 | 12:10 PM
Igor911's Avatar
The location is the same, however, the wire color is different.
Old Nov 25, 2003 | 12:19 PM
scorpiao's Avatar
Do you know what color they are?
Old Nov 25, 2003 | 12:21 PM
Igor911's Avatar
I honestly dont remember. Sorry.
Old Nov 25, 2003 | 12:29 PM
scorpiao's Avatar
no prob
Does anyone know any 00 - 01 owners who have done it so that I can ask?
Old Nov 25, 2003 | 12:48 PM
D-sta's Avatar
00-01 is the yellow wire
02-03 is the blue with silver dots
I just did the fog rewire for two of my 5th gen friends
Old Nov 25, 2003 | 01:04 PM
scorpiao's Avatar
thanks. Will hopefully rewire mine this weekend.
Old Nov 25, 2003 | 08:45 PM
Mkang513's Avatar
question. What green wire on the parking light? The one directly behind the bulb? Do I wire it to both left and right?
Old Nov 26, 2003 | 11:18 AM
bigdo26's Avatar
yes, the green wire that is directly behind the bulb.
I just re-wired my fogs and I love the look. Should have done this months ago! One weird thing tho - i hooked the green wire up to the wrong end of the fog relay wire at first and I got 1 (yes 1) HID low beam to go on along with the corner lights, but of course no fogs. It was strange. Hooked it up right immediatly after and everyhting was fine, HIDs worked, High beams, corners, everything all set so I was happy no fuses blew or worse.
Old Nov 26, 2003 | 11:47 AM
MaximaPolak's Avatar
all done
I love the HIDs in your fog lights. Thanx for the simple instructions.
Old Nov 26, 2003 | 11:59 AM
Me too......but on TURKEY DAY! (lol)
Old Nov 26, 2003 | 12:33 PM
IgS's Avatar
IgS
all done
do i have to disconnect the battery or is it just for "safety"?
Old Nov 26, 2003 | 01:02 PM
ICULookN's Avatar
I would suggest it so you don't blow some fuses accidently.
Old Nov 26, 2003 | 01:24 PM
Igor911's Avatar
If he connects it wrong anyway it will blow when the battery is reconnected.
You're just doing extra work....up 2 u
Old Nov 26, 2003 | 01:30 PM
2001SE's Avatar
to what wire on the 00/01 maximas do we tap the yellow fog wire?
Old Nov 26, 2003 | 01:32 PM
Igor911's Avatar
Did you even read the damn thread? Jesus...
"00-01 is the yellow wire" tap to the green parking light
Heat0212
Oct 24, 2020 12:36 AM
Sir Tilus
Mar 22, 2016 01:49 PM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
