Raybestos rotors
Old Nov 25, 2003 | 08:40 AM
LeoB's Avatar
Raybestos rotors
Replaced my 2000 Max's original rotors this past May with Raybestos including new Quiet Stop pads all the way around. Here I sit 12,000 miles later with both front rotors warped to hell. Thankfully the garage that installed them replaced both fronts free of charge. The other good news, Pads had only worn about 15%. I thought Raybestos was supposed to be way better than stock. Guess it can happen to any brand. At least Raybestos, I believe, have a lifetime warranty on the rotors, (according to the mechanic). Kinda scary that the Raybestos didnt last as long as the originals, (which were warped at around 20,000 miles, (replaced under warranty as well).
Old Nov 25, 2003 | 08:44 AM
Nyc2kMax's Avatar
thanks for telling us what not to Buy
Old Nov 25, 2003 | 09:35 AM
spirilis's Avatar
I have Raybestos rotors & QS pads myself, fronts AND rears have warped... fronts I got resurfaced (no problems thus far), rears I haven't done yet.
I'm thoroughly convinced the source of the problem is the rotors being too small for the application... or not dissipating heat properly. Keep in mind, others have had Brembo blanks warp as well.
Old Nov 25, 2003 | 09:36 AM
spirilis's Avatar
Also of note: When I installed my new rotors & pads, during the final reassembly I installed my calipers, then applied to brake pedal to let the calipers adjust... and THEN installed the wheels.
After getting the front rotors resurfaced, I installed the calipers, then the wheels (torqued them as tight as I could with the car still lifted), dropped the car, torqued the lugnuts and THEN applied the brake pedal to let the calipers adjust. I'll see if that makes any difference on my fronts.
Old Nov 25, 2003 | 08:46 PM
ChromeSE5's Avatar
Raybestos suck.
Old Nov 26, 2003 | 05:40 AM
kwd2kSE's Avatar
Here's an option for the rotors being too small and not dissipating heat.
http://forums.maxima.org/showthread.php?t=264963
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
