Tokico Illuminas OR KYB-Gr2s
Ok i want to get my suspension done.....i have a set of Eibach Pro kit springs sitting in my room
i want to get new shocks and struts because the stock ones cant handle them
should i go with Tokico illuminas (which are adjustable) are $500
or
KYB-Gr2s( which arent adjustable) but are like $300
i hate the floated air feeling especialy when im on the highway going the handling is horrible
but i dont want to have a horrible ride
which do u guys recomend and your reason why ??
-J
or
-J
The Illumina allows you to change the ride or handling balance of the car. It has 5 setting that adjust both compression and rebound simultaneously. You can go from almost stock ride at 1 to bumps hurt firm at 5.
Almost every lowered 5th gen is running Gr2s at the moment and most are happy with them. They are comparable to a say, 2 1/2 on the Illumina adjustment scale.
I have been waiting on the Illuminas to be released since back in the spring. They will give me the ability to select the ride i want, change it when needed, and dial out some of the understeer. To get a better idea of what actual experience people have had with them, go ask some of the guys in the 4th gen forum. I have had Illuminas in the past but not on this platform.
i have found that my eibachs are to stiff for me with my stock shocks but i am not sure if illuminas will help with that. i am thinking about buying H&R's and illuminas together. But i think that the illuminas are the best overall package (reliability, performance, cost, and precision). if you think they are to expensive then go look at koni's. now those are expensive. I personally think that illuminas are really alot better with lowered springs than GR2's and that is what it really boils down to.
Illuminas will have my $$$
Originally Posted by redstradic
i am going with the GR2's since the H&R's will not drop the car all that much. if i decide to get teins, then i will go with the new illuminas.
That and new tires will make me ALOT happier!
Anyway -- I'm definitely going to go with the Illumina / Tein combo when the Illuminas finally become available for 5th gens.
When you ask? I have no idea - and neither does anyone else on this forum.
Do I NEED the full adjustablility of the illuminas-?
No, but I SURe do WANT it!
I drive pretty aggressively, but don't autocross or anything like that.
I guess I've always wanted this car to handle more like a BMW rather than a Volvo.
Spend a little more - get the adjustability. Spend less and get a reasonably firm strut without the adjustability....the choice is yours.
Either are good, and both are better than stock.
gr
Not sure if I want to...
Not sure if I want to spend that much money to buy shocks/struts and they turn out to not be stiff enough.
I also driven agressively but don't want the ride to be overly stiff.
So, in relative terms, what is the next "stiffest" shock/strut for the Maxima?
The first thing I did was try to tame some of that FWD understeer -- a Stillen rear sway bar and -1.5 deg camber up front. Really helped, but still plenty of understeer. Not sure what to do about springs. Anybody know what the stock spring rates are for a 2k1 SE?
Mike R
Mike R
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
95Maxi
35
Sep 2, 2015 10:37 AM
