Adjusted HIDs , what a world of diffrence!
Old Dec 8, 2003 | 01:07 PM
Rafe's Avatar
I used a 8 mm socket and turned the plasric bolts clockwise(you facing the car) at a 1/4 turn. I used my garage wall to measure hight. Went to check on them last night, perfect.My first victim unfortunately was a cop who i ended up behind , the hid beams fell just over the top of his crown vic emblem. If i got on it the beam rose to his back seats. I turned off then turned the other way where traffic was coming towards me and no one flashed me, although lower vehicles like honda civics, vettes, etc, the hid beam shines slightly in there cabin. Probaly looks worse from there end, but nothing where it would cause total blindness and making them crash.
It lights up the road farther than normal, almost don't need the fog lights on. When the fog lights are on(nokya artic whites) it is very bright , but once again nothing too extreme to cause accidents.
I am happy with the adjustment, for any of you who do it make sure you have a wall to measure your old beam height and new beam height just incase you have to make any adjustments in between.
Old Dec 8, 2003 | 01:10 PM
skandalouz's Avatar
yeah i did this too... much i didn't adjust mine too much.... still needs to be a bit higher... didn't wanna adjust it too high cuz there's nothing more annoying than someone who's headlights are right in ur face
Old Dec 8, 2003 | 01:11 PM
NCTRNL's Avatar
Yeah, I just got my Maxima and I thought that the HID's were pointed just a little bit too low. Looked at it real quick and didn't see an adjustment but I will look again.
Old Dec 8, 2003 | 01:14 PM
Rafe's Avatar
Its the white plastic bolt or nub looking piece, right on the backside of the light housing. Look strait down and you will see it unless you its dirty with oil you can't miss it.
Old Dec 8, 2003 | 02:14 PM
spirilis's Avatar
My (non-HID) headlamps were way too low when I got my car used... I mean WAY too low, it was almost unsafe. The white plastic hex-head bolt did the trick (they used it back in 2k as well)
Old Dec 9, 2003 | 08:03 AM
maximalex's Avatar
I agree. I think they come out of the factory pointed too low. Think I'll adjust them this weekend.
Old Dec 9, 2003 | 10:19 AM
MaximaPolak's Avatar
I've done this like a year ago. This is not new and everyone should have thought of it because the lights don't go high enough "stock".
Old Dec 9, 2003 | 10:20 AM
Domo Kun's Avatar
ok.. dumb questions... how does one measure where the beams should be... do you face a wall some XX distance away and adjust till they are ok.... how high/low should the beam be (3 feet from ground, 3.5, etc)??
i think passenger light beam is too low....
Old Dec 9, 2003 | 07:40 PM
RichSpidizzy's Avatar
Good question! I thought i was alone on not knowing what to adjust them to.
Old Dec 9, 2003 | 09:04 PM
johnnytceo's Avatar
Here you go ....
http://dave.maisenhelder.net/bmw/headlight_aim.htm
http://www.autoshop-online.com/cchtml/elec.oh.say.html
Hope that helps. Very important to have the headlights aimed correctly especially HIDs.
Old Dec 10, 2003 | 05:00 AM
skinyc15's Avatar
Unless we are driving in a back road in the Poconos every day I really don't think we should adjust our headlights. For the most part all of us live by adequate lit roads and if we do need extra light that's what HIGH beams are for. The HID's in the MAX are pretty bright and would definetly blind somebody if we start messing with the adjustment of the height. Besides it's another reason to get pulled over by the cops.
Old Dec 22, 2003 | 08:15 AM
TitaniuMax03's Avatar
how many time are you supposed to turn for perfect height?
Old Dec 22, 2003 | 09:54 AM
2k3TitaniumSe's Avatar
Yeah, i think I have to adjust mine too.
Old Dec 22, 2003 | 11:36 AM
sweeper's Avatar
don't do it
I've been in front of people who have messed with thier lights and it totally sucks. Raising the HIDs is similar to driving with your high beams on. You pi*s people off and it's actually not the safest thing to do for other drivers who have to see glaring light in the rear and side view mirrors. I think the factory setting takes common courtesy into account.
Old Dec 22, 2003 | 11:39 AM
Igor911's Avatar
I get flashed for my fog lights all the time. People think my high beams are on so they turn theirs on. They get a surprise when I turn mine on back at them
Old Dec 22, 2003 | 11:49 AM
BeRTo175's Avatar
this mite help. its in the 5th gen How To's
http://www.autooptiks.com/aiming.html
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
