quick audio question.
Old Dec 11, 2003 | 08:59 PM
slickrick's Avatar
i need a quick response and the audio section is empty. does the 2002 non-bose h/u have 6 channels? if not, how do they have the tweeters and woofers wired to the h/u?
Old Dec 11, 2003 | 09:02 PM
jattmax's Avatar
They use crossovers, mid and bass go to the door, all the highs go to the tweeter...
Old Dec 11, 2003 | 09:04 PM
slickrick's Avatar
where are these crossovers located at?
Old Dec 11, 2003 | 09:28 PM
jattmax's Avatar
My guess would be either in the door, or behind the headunit... I work for NNA, If you dont find out let me know, I'll get you information.
Harjot
harjot@harjothundal.com
Old Dec 11, 2003 | 11:12 PM
slickrick's Avatar
Harjot
wel we have the panel off and we do not see them. any info regarding where the crossovers are and how to remove the dash would be greatly appreciated.
Old Dec 12, 2003 | 10:05 PM
maxu4ia's Avatar
mine is a bose...but I would really like to know too...thanks
Old Dec 14, 2003 | 12:29 PM
slickrick's Avatar
hasnt anyone out there installed their own h/u???
Old Dec 14, 2003 | 10:37 PM
jattmax's Avatar
Sorry ive taken some time to respond, however I would think that though crossovers are used, you should still have only 1 lead wire per channel going back to the headunit... for installing an aftermarket headunit, just hook up the corresponding harness wires to the aftermarket hu.
Hope this helps...
Old Dec 15, 2003 | 12:41 AM
slickrick's Avatar
Hope this helps...
well ive hooked up the speakers now and im buying a wiring harness for the h/u. i just need to find the crossovers and i hope they are behind the h/u? and if there is 1 channel for the mid and tweet, how do i run a crossover for the 2?
Old Dec 15, 2003 | 06:57 AM
DougJones's Avatar
There are no crossovers in the doors or behind the headunit. The door speakers are not crossed over at all. The tweeters use caps (at the tweeter) as a crossover. Once you pull the tweets, you'll see what I'm talking about.
As for wiring an aftermarket crossover, here's what you do...
(1) take output from deck/amps into your x-over
(2) take mid output from x-over to the doors (you can tap the leads right behind the deck)
(3) run new speaker wire from your x-over tweeter outputs to the tweeters you installed
You're done and ready to go.
Old Dec 15, 2003 | 07:36 AM
PoLo's Avatar
2-Wheelin it...
just agreeing with DougJones. there are no big xovers. that would cost money, something nissan is not a fan of. there are small capacitors (REAL SMALL) physically on the tweeter mount. those act as filters and stop low bass frequencies from passing. is it the best, hardly but it's something good.
i only say this in comparison to other cars stock stereo's. my crv's stereo sucks, so even though some of us dont' like the nissan non bose units, it's actually impressive compared to others. although i must say, the stock infiniti systems are pretty nice.
Old Dec 15, 2003 | 10:06 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Agreed with the crossovers. Although when adding your own aftermarket components it is Highly recommended to run them with an amp and NOT with HU power.
--Don
Old Dec 15, 2003 | 10:15 AM
slickrick's Avatar
hmm. i got my hopes up thinking they had xovers. but i removed the whole tweeter setup from the a pillar and put my tweeters in. so i ned to put my xovers on. how do i wire from the tweeter to the h/u? and will i have to run wire from the woofer to the xover also? and where should i mounth the xovers.
Old Dec 15, 2003 | 11:30 AM
DougJones's Avatar
--Don
Yes indeed. Please, if you have gone through the expense of getting seperates, use a good amp and not deck power
Old Dec 15, 2003 | 01:59 PM
slickrick's Avatar
well i have a 2 channel amp that i can run but i dont wanna install it because it takes alot of work and i dont want 2 amps running on my alternator and battery. i know deck power is not gonna show how good these speakers are but they will be loud and clear enough for me.
Old Dec 15, 2003 | 02:07 PM
DougJones's Avatar
What two amps do you have? As for the install, come on man, nut up and get it done
Old Dec 15, 2003 | 02:26 PM
slickrick's Avatar
it took me forever ot install my components and i have finals and im going home for winter break so my friend cant help me and they are his tools. i have an mtx 250 watt amp running my 2 10s but i have a jbl 600.1 coming tomorrow. i can use the mtx amp to power the fronts but then i have to run wire from the amp, to the speakers and to the h/u. im too lazy and plus i havent even installed my xovers yet which wil take a long time plus my new pioneer 8500mp hu. see... the amp can wait.
Old Dec 16, 2003 | 05:43 AM
DougJones's Avatar
Whew.... got a lot going on don't you? Well, if you ever decide to install the amps, you won't have any problems feeding them enough current.
Have fun.
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
pears
Sep 18, 2015 05:25 AM
